File your melted/cracked DTRL complaint with NHTSA, force Toyota to recall and fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ray, Jul 9, 2012.
  1. Jan 11, 2014 at 4:05 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Your '05 most likely does not have DRL from the factory.
    My '08 doesn't either. It was not included with all option packages until '12 or so... may still not be included with the base model.
    On our trucks, the two lights in the center are only turn signals, the two on the sides are parking lights.
  2. Jan 12, 2014 at 11:08 AM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    The instructions are generic, I think they cover a number of applications. Essentially, you have different rubber gaskets and trim rings to fit the different keyways of certain bulbs.
    There is a control box that interprets the DRL signal (white light) vs the turn signal (amber light), and it also acts as a resistor. Hardest part was figuring out a place to mount the box (1 for each side). From there it is plug and play. Remove old incandescent, plug in CK base adaptor, plug in control box wire, set up the Triton LED, you can adjust the depth relative to the reflector, and enjoy.
    For the '12 and up guys, there is a lead wire they can tap so the DRL dims to 50% when headlights are on.
    Very easy mod, if one has even a dram of mechanical ability.
  3. Mar 4, 2014 at 2:32 PM
    timmy2112
    timmy2112 Well-Known Member
    I just filed my complaint, I guess we will see what we will see!!
  4. Mar 4, 2014 at 2:54 PM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    C'mon toyota. Lights are as basic as you can get on a damn truck with thousands of parts on it! What a joke.
  5. Mar 4, 2014 at 4:28 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Glad I live in the north country mine are fine damn if I'll buy two turn signal bulbs for a $140! Any one ever though about venting them?
  6. Mar 4, 2014 at 5:55 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I just leave mine off. Glad I have that option on 2013.
