Fillin'er up ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoeN 267, Nov 23, 2009.
  1. Nov 23, 2009 at 12:53 PM
    fatty ac1d
    fatty ac1d Well-Known Member
    Kansas
    15 MGM DCSB SR5
    I usually let it stop, wait a few seconds, then go to a price that I can recognize on my billing statement. Like $xx.00, $xx.25, $30.30, etc.
  2. Nov 23, 2009 at 12:57 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    till it pops...I dont want to take the chance of is spewing out...oh did I just say that!
  3. Nov 23, 2009 at 1:03 PM
    jlvhrse
    jlvhrse Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    I usaully top it off...
  4. Nov 23, 2009 at 1:03 PM
    Fore
    Fore Well-Known Member
    07 PreRunner
    If you want to keep an accurate account of your MPG you should pump till it stops automatically. Also, you should never allow it to go below half a tank so that you don't dry out the float sensor inside the tank. Yes, it will happen for those who live in hotter climates during the summer.
  5. Nov 23, 2009 at 1:12 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    That's 100 % correct. You can try to top it off, but if your gas station has a vapor recovery system (All california stations do) at some point you are just paying to put gas back into the gas station's tanks. Plus, if you are using a credit card, why bother rounding to the nearest dollar?
    In conclusion, save some money and stop filling when it pops.
  6. Nov 23, 2009 at 3:45 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I go until it stops. Don't add no more because I hate spillage
  7. Nov 23, 2009 at 4:12 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    On the Dakota I had if you turn the nozzle to "aim" down the hole it went in easier, but you should finish off on the slow notch so it fills up a bit more.
    Not supposed to top off btw, nozzle nazis will take you to the gulag. I'm lobbying to allow topping off the last 25 cents to round off though j/k
  8. Nov 23, 2009 at 7:42 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i put it in till it want hold anymore,that way i want have to stop till the next evening!
  9. Nov 23, 2009 at 7:48 PM
    CUtigerfan
    CUtigerfan Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    Is that why my gauge goes up above F when I fill up? I run it til it stops and then go to the next whole dollar. I bought it used though and don't know how the previous owner filled it up.
    The gauge on the Honda I drove before wasn't right either. My Mom drove it for 14 years and I know she normally pumped a little bit more after the pump cut off.
  10. Nov 23, 2009 at 7:56 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    arent you only supposed to pump till it pops for emissions reasons as well??
  11. Nov 23, 2009 at 7:57 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    OK, here in Oregon it is illegal to pump your own gas. Yeah, that's correct.. they really won't let you even touch the pump. So, it seems to be the practice of the fuel transfer engineer (a.k.a: the minimum wage worker who pumps your gas) always tops off your tank to the nearest dollar. Must be some state law also???
    Anyway, I don't like it, nor do I recommend that to anyone.
    When I am outside the state of Oregon I always stop at the pop.
    Strange huh? Who knew?
  12. Nov 23, 2009 at 8:02 PM
    Tacoyota
    08 4wd
    I'm from Oregon,at work I fill my own rigs luckilyand just leave on the low notch. Where I fill up on my rig, the rocket janitors won't top off, unless its that close to a whole dollar.
    .....p.s. Vancouver isn't Oregon:laugh: can't help it sorry
  13. Nov 23, 2009 at 8:16 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Yes.
    http://www.epa.gov/donttopoff/
    Also, the reason gas nozzles are required to have a hold open latch isn't for the convenience (although an added benifit), it is so you don't have to stand next to the nozzle thereby reducing your exposure to benzine and mtbe.
  14. Nov 23, 2009 at 8:23 PM
    fatty ac1d
    Kansas
    15 MGM DCSB SR5
    Alright, here's a few things for you gas experts to debate:
    - I fill up only in the mornings. When the gas is warm in the afternoon or evenings, you're not getting exactly a gallon because the gas is less dense.
    - When I fill up I use the lowest setting. This minimizes the vapors coming out.
    - I also don't fill up when the fuel truck is there; it stirs up the dirt.
    Discuss.
  15. Nov 23, 2009 at 8:33 PM
    #35
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    - The tanks are underground and 10 - 15k gallons each on average. The temperatures are very constant throughout the day.
    - The speed at which the gasoline comes out is regulated. It cannot exceed 10 gpm (gallons per minute). Pumping slowly is actually discouraged because it may not allow the vapor recovery system to operate properly.
    - All tanks have submerged fill pipes thereby minimizing mixing. Additionally all dispensers have filters on them, so feel free to fill whenever you wish.
    Any other gasoline station questions?
  16. Nov 23, 2009 at 8:35 PM
    #36
    Tacoyota
    08 4wd
    although gas has a low vapor point, its not warm enough here to worry about it, and when it does hit 95 degrees the 75 degree morning has plenty of vapors.
    I agree cold gas is more dense but you wont get enough to add up in a decade filling at 50 instead of 80 degrees
    enough things to worry about , them is minor.
    they use filters, on stirring the dirt, and I never see the truck enough to worry.See it all the time at work and never had a problem with sediment.
  17. Nov 23, 2009 at 8:38 PM
    #37
    timbo805
    timbo805 Well-Known Member
    SanDiego
    09 tacoma trd sport pre-runner
    i always fill er up to the neck no problems + it takes about a day for the gage to go down
  18. Nov 23, 2009 at 8:41 PM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I fill until it stops.....
  19. Nov 23, 2009 at 8:42 PM
    #39
    Tacoyota
    08 4wd
    I like to go on slow notch to give me more time to wash the windows , gonna get one of them fake electric sickerettes to freak people out at the pump:D:eek:
    How do you make a cat sound like a dog?....... pour gas on it and light. WOOOF!!
  20. Nov 23, 2009 at 8:53 PM
    #40
    fatty ac1d
    Kansas
    15 MGM DCSB SR5
    Nope.
    Thank you kind sir for enlightening me.
    :bowdown:
