Filling 2.7L cooling system.
Discussion in 'Technical Chat' started by cosmicfires, Jan 28, 2014.
  1. Jan 28, 2014 at 8:58 PM
    cosmicfires
    cosmicfires [OP] Well-Known Member
    David
    Lynnwood, WA
    2009 Regular Cab 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I drained the cooling system on my 2009 4.7L (4 cyl) Regular Cab Tacoma to replace the coolant.
    I got about 9 quarts out, I can only get 6+ quarts in. I've run the truck up to operating temperature, the thermostat doesn't open. It doesn't overheat. I drove the front end up a gravel pile to 30 degrees which didn't help.
    Advice please.
  2. Feb 1, 2014 at 10:21 AM
    Indy
    Indy Master of all I survey.
    Buy a flush kit at walmart, costs about $3. Install in the top heater hose by the firewall. Its the highest point so all the air will be easy to get out.
