Filling Differential/Transfer Case
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Jan 10, 2012.
  1. Jan 10, 2012 at 6:13 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    I'm not quite sure If I remember correctly but can the fill hole also be used as like a "dip stick". By that I mean once it's up to the fill plug it has the correct amount?
  2. Jan 10, 2012 at 6:14 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That's exactly what it's for.....filling and proper amount.
    The hole is positioned there for a reason, so you CAN'T overfill it. When filling - always make sure the truck is on LEVEL ground.
    If the truck is on level ground, you can open up the fill hole and stick your pinky finger (or other clean device) in there to check the oil level.
  3. Jan 10, 2012 at 6:29 AM
    MQQSE
    MQQSE Afoot is the game
    Rob
    Palmer, AK
    Yep! :thumbsup:
  4. Jan 10, 2012 at 10:40 AM
    jeremy_283
    and this will work for the front differential, transfer case, and rear differential?
  5. Jan 10, 2012 at 10:45 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
  6. Jan 10, 2012 at 10:49 AM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Some manufacturers say to fill it just below the fill hole. That's most likely to minimize the seepage of oil out of the drain plug. Yeah they can leak when properly torqued... But fill it until you get a nice stream coming out. Grab your plug and screw it in.
  7. Jan 10, 2012 at 11:04 AM
    Janster
    Jandy
    Lancaster, PA
    Yes...
    Just make sure you know EXACTLY where the fill holes are.
    As a basic clue - Fill holes are usually in the middle (half way up) on the item at which you are trying to do the oil change on.
    DO NOT put oil in a hole that's located at the TOP - this should be a clue that you're not using the right hole. Overfilling can be just 'as harmful' as not having enough oil.
  8. Jan 10, 2012 at 12:23 PM
    MQQSE
    Rob
    Palmer, AK
    :thumbsup:
