Filling diffs, t-case.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Aug 18, 2019.
  1. Aug 18, 2019 at 6:52 PM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    I changed the fluid in my front diff and t-case today, and was reminded how much I hate this shitty pumps that screw onto the qt bottles. Has anyone found a reasonably high quality alternative?
    Those janky pumps can't be the only option.
  2. Aug 18, 2019 at 7:11 PM
    Fury
    Fury Well-Known Member
    The synthetic gear lube jugs I get have the cone shaped tops on them so I just squeeze into the rear and t-case. I use a plunger pump on the front that looks like a grease gun. 15 bucks and works great.
  3. Aug 18, 2019 at 7:18 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    1.5 gallon garden sprayer. Lop off the wand. Grab a plastic valve that fits the 1/8" line. Cut the line 12" from the pump, insert the valve, snake the remainder of the line into the diff/tranny.
    Pressurize, open valve to flow the lube, close valve when full.
  4. Aug 18, 2019 at 7:49 PM
    ejwan
    ejwan Well-Known Member
    Can use a drill to spin an speed sensor valve body. Its from an integra/civic that uses a cable speed odometer meter. The pump circulate ps fluid. I got mines for free and love it. I’ll take a picture later.
  5. Aug 18, 2019 at 7:51 PM
    koditten
    Kirk
    Central Michigan
    Why not.
    People have been using car engine oil pumps to do exactly the same thing.
  6. Aug 18, 2019 at 7:56 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I had previously used a "grease-gun" type plunger pump like @Fury mentioned, but it bypassed too much internally that it couldn't draw fluid from the bottle, so I had to unscrew the cap and fill the gun each time. Switched to this type instead:
    https://www.amazon.com/gp/product/B01N987ZL5/
  7. Aug 18, 2019 at 8:00 PM
    omegaman2
    omegaman2 Unknown Member
    2015 4WD DCSB
    Amsoil offers gear oil in flexible squeeze bags
  8. Aug 18, 2019 at 8:01 PM
    uncle ed
    uncle ed Well-Known Member
    Ed
    CA Eastern Sierra
    2007 & 2019
    Garden sprayer
    Cut the spray tip off
    Less than $20 on Amazon
    Works great and easy
  9. Aug 18, 2019 at 10:13 PM
    ejwan
    Long hose goes to tranny/diff short hose is my new fluid.
    Pressure sprayer should work too. Probably easier to get a hold of.
    tinker_troy and koditten like this.
  10. Aug 19, 2019 at 12:45 AM
    AlbertaSparky
    AlbertaSparky Self Made Hundredaire
    Cam
    Sundre, AB, Canada
    '08 BSP DCSB Sport
    Punch a hole in the bottle near the neck, insert 1/4 tubing to bottom of the bottle and run into diff. Drill a hole in the cap, use air compressor at very low pressure with blow gun to push the fluid up through the hose into the diff.
  11. Aug 19, 2019 at 1:36 AM
    ImBillT
    ImBillT Well-Known Member
    2010 4x4 base
    Stick a clear hose into the pointy nozzle on the end of the bottle.
  12. Aug 19, 2019 at 2:01 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    Wow, lots of good alternatives! The garden sprayers will flow heavy gear lube?? I would think it was too thick.
  13. Aug 19, 2019 at 5:47 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I could be on crack but I thought I was able to pour the fluid directly into the T-case?
    You can pour directly into the rear diff too, if you remove the spare tire. Next time I do the front, I am going to try to fill from the top with a funnel and long piece of clear hose.
  14. Aug 19, 2019 at 6:07 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    Maybe I just went straight to the pump out of habit. My first time doing it on a Tacoma.
