Filling gas cans
Discussion in '2nd Gen. Tacomas (2005-2015)' started by savedone, Sep 3, 2014.
  1. Sep 3, 2014 at 4:25 AM
    savedone
    savedone [OP] Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    I thought I would pass this along about filling gas cans in the bed of the truck since the Tacoma has a composite bed. Better safe than sorry. ;)
    http://www.cdc.gov/niosh/docs/98-111/
  2. Sep 3, 2014 at 4:33 AM
    Large
    Large Red
    I guess I always thought that filling a portable gas container on the flat ground was common sense, since there are stickers all over almost every pump I've seen. Good info nonetheless.
  3. Sep 3, 2014 at 4:50 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    You'd be surprised how many morons I see filling tanks in all sorts of moronic situations while working at 7/11!
    We also have a few scumbag regulars that smoke, yes- SMOKE, at the pumps. Tards just never learn. I've kicked them out so many times
  4. Sep 3, 2014 at 7:44 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Another good reason to get a bed mat.
  5. Sep 3, 2014 at 7:50 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    How do you ground your bed mat? The issue is the bed mat AND composite bed are insulators and static is created by gasoline droplets falling through the air...
    Now a unpainted, clean, METAL bed with a static chain to the ground works pretty good...
    The most dangerous thing in a powder plant is a lady wearing silk stockings...
    Howard
  6. Sep 3, 2014 at 8:03 AM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    so, the cellphone thing was myth"busted" but the static is a REAL problem. It has been caught on security cams...
  7. Sep 3, 2014 at 8:17 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Yes. Cellphones do NOT create static. YOU create the static usually while exiting the vehicle. It's a good habit to touch the vehicle AFTER you exit and BEFORE you touch the pump. This will discharge any static that may have accumulated on you while exiting. Also, it's the gas FUMES not the liquid which is combustable which is why it's dangerous while refueling as a lot of fumes are created during the transfer from the nozzle into the tank.
    My first Toyota pickup, an 88', used to give me a shock EVERY time I exited. Enough that it was somewhat painful. Likely an poor ground in the system somewhere.
  8. Sep 3, 2014 at 8:19 AM
    hetkind
    Howard
    Johnson City
    Not "fumes", but "vapor". Fumes are condensed metals, from airborne liquid form, vapors is the evaporate from a substance that is normally a liquid at the temp in question.
  9. Sep 3, 2014 at 8:21 AM
    hetkind
    Howard
    Johnson City
    taping the nozzle on the tank does NOTHING, but can CREATE a metal on metal spark. The fuel HOSE is conductive and will drain off the static in the hose and nozzle. It does nothing for the static created on the plastic gas can.
    Howard
  10. Sep 3, 2014 at 8:32 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Is the bed an insulator? Should be interesting to take a multimeter to it. Not sure what mix of chopped glass and carbon fibers Toyota uses in the SMC material.
  11. Sep 3, 2014 at 8:43 AM
    hetkind
    Howard
    Johnson City
    yes, composite beds and bed liners are considered insulators...it is the RESIN and the CHOPPED GLASS which are the insulating elements, and if you don't have exposed carbon fibers, and the fibers aren't continuous, you have a fine insulator. Do the beds transmit and radiate heat easily?
  12. Sep 3, 2014 at 11:38 AM
    savedone
    Gerald
    Texas
    A bed matt adds to the problem, it does not fix it. The only fix is to fill the can on the ground.
  13. Sep 3, 2014 at 11:51 AM
    savedone
    Gerald
    Texas
    This is not exactly incorrect. Touching the can prior to opening it will drain off some static, but the main problem is in the pumping. As the gas is forced through the hose while pumping the friction from the gas rubbing against the inside of the hose and nozzle causes friction which causes static and as it fills the tank at that fast rate that also causes static in the tank. If the can is not grounded in some way the static can cause a spark and explosion. Plastic cans will also discharge static if setting on the ground which they cannot do if setting in a composite bed or bed mat.
  14. Sep 3, 2014 at 12:48 PM
    Collins
    North Carolina
    I was more thinking of the gas can sliding around on the composite
    bed...the mat does help with that of course.
    I'd think this problem (if you can call it that) would be much more prevalent with really low humidity.
    Right now in NC it would not be a problem...but good idea to be safe
    and fill on the ground.
  15. Sep 3, 2014 at 2:19 PM
    MarkH
    MarkH Well-Known Member
    Mark
    San Jose, CA
    13 PreRunner TRD Off Road
