Filling/resolving windshield scratches?
Discussion in 'Detailing' started by bshammer0, May 2, 2018.
  1. May 2, 2018 at 11:49 AM
    bshammer0
    bshammer0 [OP] Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Many folks have mentioned this before but I haven't seen any clear answers.
    Problem: These windshields are weak. Already had to replace one just a couple months into ownership (wasn't even behind anything when it cracked - but had turned my defrost on for the first time...)
    Now a year later I have tiny scratches all over the windshield. I drive the same routes I always have and I've never had this kind of wear on a windshield. It almost looks like tiny bits of lint on the windshield in the sunlight but they are tiny scratches.
    Question: I've never had great luck w/ waxes on windshields but what fillers/protectants are folks using and how can I clear up the scratches I have with something that has some holding power?
  2. May 2, 2018 at 11:55 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  3. May 2, 2018 at 12:02 PM
    CMD-KY
    CMD-KY Well-Known Member
    South Central Kentucky
    2104 Tacoma AC SR5 4wd
    wilcam47[QUOTED] likes this.
  4. May 2, 2018 at 12:03 PM
    bshammer0
    Brandon
    Nashville, TN
    does look like a potential solution for the instrument cluster plexiglass though... tried a few other things that don't entirely fix those but still curious how this would fare on actual glass
    wilcam47 and CMD-KY like this.
  5. May 2, 2018 at 12:04 PM
    wilcam47
    Will
    Bourbon state
    if its scratching easy I'd try it...
    bshammer0[OP] likes this.
  6. May 2, 2018 at 12:06 PM
    wilcam47
    Will
    Bourbon state
    this stuff is expensive on a quick search but does work great...used to be available at motorcycle places. They use it on their windscreens...
    https://www.jpcycles.com/product/90...MIg5aOnNzn2gIVC4NpCh0Hmg1EEAQYAiABEgKaGfD_BwE
  7. May 2, 2018 at 6:21 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    The only way to remove defects in glass is with a cerium oxide slurry and a DA or Rotary polisher.
    CarPro makes a product called ceriglass and they also have rayon pads for polishers. Just a heads up-- it's a lot of work and takes a long time.
    There are some good how-to threads on the Autogeek detailing forum that take you through the process. Maybe google "Mike Philips glass polishing" and see what you find over there.
