Filling the gas tank
Discussion in '1st Gen. Tacomas (1995-2004)' started by SunDevilTacoma, Jan 3, 2010.
  1. Jan 3, 2010 at 6:57 PM
    SunDevilTacoma
    SunDevilTacoma [OP] Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    I did a quick search and didn't see anything on this, but when I fill the tank I don't ever really fill it up. The needle gets as high as the top of the gauge, to the F, but not any higher. This is the only vehicle I've ever had a problem like this with, even my '84 and '85 Toyotas didn't have this problem. I fill up as slowly as I can but it doesn't matter. Anyone else have this issue? Is there something I can modify or is it what it is? Thanks.
  2. Jan 4, 2010 at 5:34 AM
    slickyd
    slickyd Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    does it really matter. as long as the pump cut off its full. It just means that your gas hand will stay on F a little longer.
  3. Jan 4, 2010 at 8:27 AM
    SunDevilTacoma
    Doug
    Gilbert, AZ
    You're right. I think it's more a personal annoyance than anything else. Thanks.
  4. Jan 4, 2010 at 8:39 AM
    SunDevilTacoma
    Doug
    Gilbert, AZ
    Ok, how do you know? You told me to ask...
