Filling transmission fluid through the shifter?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Moco, Mar 14, 2013.
  1. Mar 14, 2013 at 4:52 PM
    Moco
    Moco [OP] Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    Hey guys,
    Getting ready to change transmission fluid on my 96 4x4 2.7L 5spd. I took a peek under the truck and IDed the filler and drain bolts. However, know on my old mustang, it was possible to re-fill the transmission by removing the shifter from inside the car and pouring transmission fluid in from the top.
    My question is, can this also be done with the transmissions in our Tacomas or is the only way to fill it through the fill hole?
  2. Mar 14, 2013 at 4:58 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I'd like to know as well.
  3. Mar 14, 2013 at 6:59 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Why not just fill it through the sides? Going to need to check the level of fluid by removing the filler plug anyway.
  4. Mar 14, 2013 at 7:04 PM
    Moco
    Eric
    NoVA
    Going to have the truck on jackstands. Draining will be no problem - but looks like it might be a tight squeeze / require a filler tube to fill the tranny. Would be no problem if it was on a lift, but if I'm crouched and contorted under the truck, trying to squeeze fluid into the tranny, I'd rather do it from up top if its possible.
  5. Mar 14, 2013 at 9:38 PM
    SpeedoJosh
    Florida
    Check out those fluid pumps from the auto part store. They're like 5-10 bucks, and they are awesome. I used one when I did my trans, tcase, and diffs. Really makes the job easy.
  6. Mar 14, 2013 at 9:41 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    it is possible to fill from the shifter you will have no problem with it
  7. Mar 14, 2013 at 9:42 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Yup, done it on Kolt's truck, his fill plug is blocked by a t-case mount, mostly.
    I'd rather use a pump and the fill plug though.
  8. Mar 15, 2013 at 2:20 AM
    Moco
    Eric
    NoVA
    Cool. Thanks. This will be on my weekend to-do list.
  9. Mar 15, 2013 at 2:20 AM
    Moco
    Eric
    NoVA
    Got it. Thanks.
    Max, your truck is rolling sex dude!
  10. Mar 15, 2013 at 2:37 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Thanks man. :eek:
  11. Mar 15, 2013 at 7:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I would highly recommend NOT filling the transmission thru the shifter.
    You can possibly OVERFILL it....and that's just as bad as underfilling it.
    The FILL plug is on the side for a reason - designed so you can't overfill it.
  12. Mar 15, 2013 at 9:03 AM
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    i'M GUESSING THE op WILL CHECK FOR THE PROSCRIBED PORTION BY CHECKING AT THE FILL PLUG WHEN HE'S FINISHED POURING. :cool:
  13. Mar 15, 2013 at 9:49 AM
    Moco
    Eric
    NoVA
    Good advice, thanks. Im still going to go through the shifter, but I will start checking at about 75% of capacity.
    I will have the fill plug off since I am replacing both the drain and fill plug with new bolts (just for cosmetic reasons and to ensure new fresh headed bolts are in place).
  14. Mar 15, 2013 at 9:49 AM
    Moco
    Eric
    NoVA
    That is a reasonable assumption.
  15. Mar 17, 2013 at 6:35 AM
    Moco
    Eric
    NoVA
    Just an update for anyone that's interested:
    I changed my tranny fluid yesterday. Like I said, draining it was no sweat - I took both the filler and drain plug out and let the fluid drain. I tried using the filler hole, but it was just too much pain in the butt. Instead, I just went into the cab, took the boot and shifter off, and poured tranny fluid through the shifter hole. Easy as pie and no squeezing the shit out of the bottle to get it through hose to get it to the fill hole.
    I don't know why everybody doesn't do it this way.
  16. Mar 17, 2013 at 7:18 AM
    SpeedoJosh
    Florida
    B/c I have a fluid pump. As simple as unscrewing fluid bottle, and screwing the pump onto it, then just pump away. Clean and easy
