Filter Side Faces Which Side?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WATacoRider, Nov 16, 2012.
  1. Nov 16, 2012 at 1:45 PM
    WATacoRider
    WATacoRider [OP] Well-Known Member
    TRD Sport 4x4
    Got an AFE dry filter. I want to make sure the previous owner didn't install the K&N wrong.
    You see the "thinner" side? Does that face the engine or intake tube?
    I tried both directions and it fits both ways. I also dont see any airflow arrows like cabin filters, so not 100% sure.
    A
    B
    When I removed my old filter, it was the "A" diagram. Rich is stating to go with "B"..... I saw a post with an old K&N filter and looking at how dirty one side is, it appears they always installed it like "A" diagram...... So like wtf. Ignore how the filter tapers in the diagram. It's obvious that which end goes to which end. It's just the orientation of the face of the filter that I'm concerned about. Just couldn't find the proper image.
  2. Nov 16, 2012 at 3:32 PM
    ElkHunter
    ElkHunter Member
    Mark
    Oregon City, Oregon
    2012 TacomaAccess Cab SR5 4x4
    I just finished installing a K&N drop in, and the way it is pictured is the way it goes in...
    Mine(2012 4 banger) only goes in one way so, watch for that...
  3. Nov 16, 2012 at 9:28 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Paper filters filter better than those.
  4. Nov 17, 2012 at 9:15 PM
    WATacoRider
    TRD Sport 4x4
    Too late now. Already have the AFE in hand.
  5. Nov 17, 2012 at 9:24 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Filter will only fit in one way. Skinny side faces toward engine.
  6. Nov 18, 2012 at 11:43 AM
    WATacoRider
    TRD Sport 4x4
    Skinny as in the gasket part?
  7. Nov 18, 2012 at 11:46 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The way the image is oriented, airflow moves top-down, so the "bottom" of the picture goes toward the engine.
    On the 2.7, the filter goes in exactly as shown.
    On the 4.0, the top of the image goes toward the passenger fender.
  8. Nov 18, 2012 at 11:47 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    And +1... those filters are shit.
    Seriously. OEM filter is $15. They are changed every 30,000 miles.
    Is $45 every 100,000 miles too much to ask for a better filter?
  9. Nov 26, 2012 at 7:45 AM
    jeratbp
    jeratbp Well-Known Member
    Jeremy
    Norfolk, VA
    '05 4Runner Sport V8
  10. Nov 26, 2012 at 7:57 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    OP even try to just fit it in there? i imagine that thing can only go one way. i cant see it fitting in there, all closed up BOTH ways. no way.
    damn. the car projects do get more difficult. :D
  11. Nov 26, 2012 at 8:11 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Yep
    It's a trapezoidal shape so it will only fit one way. The small end has a 90 degree angle and an obtuse angle, whereas the large end has a 90 degree and an acute angle.
  12. Nov 26, 2012 at 7:39 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You forgot....
  13. Nov 26, 2012 at 8:49 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Flat side faces the engine, "smaller" inlet part faces the intake tubing.
    And I can't say enough about my AFE. Paper filter SUCKS if you wheel a lot. If I still had the paper one, I'd be replacing it once a month with the amount of dust that gets in there.
    AFE is super easy to clean. Just dunk and swish in soapy water, rinse, let it dry, and re-install.
  14. Nov 27, 2012 at 12:44 AM
    WATacoRider
    TRD Sport 4x4
    Is the frame on the stock filter rigid? The AFE is soft, so I think that's why I can fit it in either direction.
    As stated in my original post, ignore the tapered and wide ends. It's obvious which end is which. It's just which face is which I'm having issues with. Sounds like "The Traveler" is confirming it is "A". Which is the way I currently have it set up at the moment.
  15. Nov 27, 2012 at 9:14 AM
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Based on the size of the engine in this diagram it is for a 3.7L engine.
    So.... basically this is all wrong.:rolleyes:
  16. Nov 27, 2012 at 6:56 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    He's got a 2007... pretty sure that's a 4.0 ;)
