Final decision on rims and tires. Need Help!
Discussion in 'Wheels & Tires' started by RYAN87GT, Dec 6, 2010.
  1. Dec 6, 2010 at 5:48 AM
    RYAN87GT
    RYAN87GT [OP] Member
    Wilmington Delaware
    The Rims and tires are for my girlfriends 98 4X4 tacoma. Im getting them for her for christmas.
    I have come up with 265/75/16 tires. I am aslo getting 16 inch cragar soft 8's. I need to know what specs for the rim.
    (What backspacing)
    (what Width)
    (What Bolt pattern not sure of the stock bolt pattern)
    anything else?
    everything i need to order these rims.
    thanks guys i appreciate it alot.
    Ryan:D
  2. Dec 6, 2010 at 5:52 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    4.5" backspacing
    7-8" width
    6 on 5.5 (139.7) bolt pattern
    Make sure that, if they are hub-centric, the hub bore is for a toyota and not a chevy. Chevy wheels won't fit toyotas unless you have a shop bore them out.
  3. Dec 6, 2010 at 6:04 AM
    RYAN87GT
    Wilmington Delaware
    ok coll thanks again buddy. what deos hub-centric mean?
  4. Dec 6, 2010 at 7:03 AM
    KPT
    09 Prerunner
    Hub-centric wheels use the whee; hub to center themselves. Lug-centric rims are centered by the lug holes.
  5. Dec 6, 2010 at 7:15 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    my girlfriends has these on her 01 4runner. she has michelin ltx ms2 or something on them. they are alright wheels. they arent anything special. dust/dirt sticks to them like none other as well.
  6. Dec 7, 2010 at 4:58 AM
    RYAN87GT
    Wilmington Delaware
    ok here they are this is all i can get. i decided to switch to 15inch rims. will these still work?? and i cant find out if they are hubcentric or not. i know i have tio get the different lugnuts for them. let me know.
    thanks,
    Wheel Diameter
    15 in.
    Wheel Width (in)8.000 in.Wheel MaterialSteelPrimary Wheel ColorBlackWheel FinishGlossManufacturers Wheel SeriesCragar Soft 8 SeriesBackspacing (in)4.000 in.Offset-12.00mmWheel Construction2-pieceBeadlock IncludedNoBeadlock FunctionalNoLug Nut Seat StyleConical seat - 60 degreeHub CentricNoCenter Bore Diameter (in)4.250 in.Center Cap IncludedNoValve Stems IncludedNoQuantitySold individually.
  7. Dec 7, 2010 at 5:01 AM
    RYAN87GT
    Wilmington Delaware
    ok it does say they are not hub centric. ok i got that. but will they still work even tho they are 4" backspacing? and offset is -12.00mm ?
  8. Dec 7, 2010 at 5:42 AM
    KPT
    09 Prerunner
    4" backspacing is fine on 1st gens.
  9. Dec 7, 2010 at 5:53 AM
    RYAN87GT
    Wilmington Delaware
    ok aweosme big reliefe. ok how about lug nuts i found out that they have to be conical seat 60 degrees. and they have to be 12mm x 1.50 RH. is that the length too? or how long should they be. and how abnout open end or closed.
  10. Dec 7, 2010 at 6:00 AM
    KPT
    09 Prerunner
    12mm x 1.5 is the thread and pitch.
    They can be whatever length you prefer (standard or long). I would go with closed but it really doesn't matter, whatever you like.
    Her truck didn't come with conical seat lugs? (I don't know much about 1st gen stock wheels)
    WheelersOffroad.com has an excellent selection of lugs nuts btw.
  11. Dec 7, 2010 at 6:02 AM
    RYAN87GT
    Wilmington Delaware
    no itsa got reg lugs with washers.
  12. Dec 7, 2010 at 6:03 AM
    RYAN87GT
    Wilmington Delaware
    but thanks alot uve been more than great.
  13. Dec 7, 2010 at 6:04 AM
    KPT
    09 Prerunner
    No problem.
  14. Dec 7, 2010 at 6:05 AM
    RYAN87GT
    Wilmington Delaware
  15. Dec 7, 2010 at 6:05 AM
    KPT
    09 Prerunner
    sure will.
