Finally, a '14 sport with temp in the mirror!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hotrod53, Aug 6, 2016.
  1. Aug 6, 2016 at 4:22 PM
    hotrod53
    hotrod53 [OP] Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    i just can't take it anymore, HD reception makes this temp display completely unreliable..... I made a purchase from Bob's mirrors and put a Gentex in my '14! It took me about 2 hours to install the mirror, the sensor, and then button in all back up. I didn't remove the grill as the directions said, but it would have made the job easier, and I have the cuts and bruises to prove it.
    Over all not a bad job, the harness is plug and play, removing the overhead console is only 1 screw, removing the drivers sun visor is 2 screws, removing the kick plate and the door plate were just clips, remove the drivers grab handle was 2 10mm bolts, and there is an open hole in the firewall that you can easily fish through. I chose to use an existing hole out in front of the radiator behind the grille and just below the OEM sensor, you'll have to double nut the bolt to space it out a bit. Solder or crimp 2 wires and you're in business!
    If you're considering this project, I must say that the pictures and directions that Bob's supplies sure makes the job much easier!
