Finally an aftermarket diff lock actuator?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ktaco, Jul 13, 2016.
  1. Jul 13, 2016 at 7:43 AM
    Ktaco
    Ktaco [OP] Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    So I search now and then for good prices on used diff lock actuators. Yesterday i stumbled across this on ebay.
    http://m.ebay.com/itm/391462403812?_mwbanner=1
    Made by Dorman. Now I realize Tacoma's are not listed in the application guide but it certainly looks very simular to what the Tacoma uses. I have never heard or seen mention about this aftermarket option available before.
    Has anyone actually tried this actuator or is this your first time seeing it too?
  2. Jul 13, 2016 at 8:55 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    looks identical to me...
  3. Jul 13, 2016 at 8:59 AM
    Ktaco
    And at a 1/3 of the dealership cost here in Canada.
  4. Jul 13, 2016 at 11:39 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    I wouldn't trust it. Dorman is usually pretty good about getting their applications correct. there has to be something about this that isn't equal to OE. now, thats saying that it needs to be equal to OE to be listed for a tacoma. if the difference is the molding of the casing, but fit form and function are exactly the same and works. then fuck it, go for it! just keep in mind, if you install it and it doesn't work. you will NOT get a refund. who wants to put 400 bones on the line for the rest of us?
    honestly, your probably better off sending the thing to an electric motor rebuild shop.
  5. Jul 18, 2016 at 12:25 PM
    charkear
    charkear Member
  6. Jul 18, 2016 at 12:55 PM
    devinzz1
    devin
    2023 aclb trd or mt
    i even counted the same amount if teeth on the gear. maybe a different connector but wires should do the same.
  7. Jul 18, 2016 at 8:09 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    thats a lot of coin, you can buy whole diffs with motor for that price
  8. Apr 28, 2020 at 11:40 AM
    kvtrd
    kvtrd New Member
    99 tacoma trd
    bit late to this but did anyone find out if that worked. my oe one exploded thanks to mto ont. and there toxic road brine in winter time
  9. Jul 28, 2020 at 2:41 AM
    krn_taco90
    krn_taco90 Well-Known Member
    Jonathan
    2019 Super White Tacoma TRD pro
    RRW Rock sliders/Front pro grille lights
    mine too let me know the updates
  10. Jul 28, 2020 at 5:35 AM
    MoneyB86
    MoneyB86 Well-Known Member
    Reagan Country, CA
    2019 MGM Tacoma Double Cab
    I replaced mine recently. I went with Aisin. Cheaper than OEM Toyota, but slightly more than Dorman. As a FYI, Aisin is owned by Toyota. Aisin builds all the transmission components for Toyota. I bought their locker actuator over Dorman because I knew I was getting an OEM product without the Toyota price. It fit in perfectly and works perfectly as well. Hopefully this helps.
    Hamer95USA likes this.
  11. Jul 28, 2020 at 7:48 AM
    dblees
    dblees Well-Known Member
    Dave
    SW Oregon
    02/01 TRD mongrel
    Just put in an Aisin actuator here also, exactly like the original. & don't forget to check the breather tube...
  12. Jul 29, 2020 at 4:16 PM
    krn_taco90
    Jonathan
