Finally did it
Discussion in 'Audio & Video' started by Casey05Taco, Sep 20, 2011.
  1. Sep 20, 2011 at 9:20 PM
    Casey05Taco
    Casey05Taco [OP] Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    Finally let my friend click the checkout button for buying my new double din headunit. Decided on getting the AVH-p4300 from pioneer. Now i gotta go out and grab that toggle switch and some wire for this dvd bypass.
  2. Sep 20, 2011 at 9:24 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    nice! and dont feel bad, I just spent 1000 on a new computer.
  3. Sep 20, 2011 at 9:28 PM
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    i feel alot better as i only spent 410 on the headunit, wiring, scoshe dask kit and ipod cable
  4. Sep 20, 2011 at 10:20 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    good luck with it, post pics when you get it installed
  5. Sep 21, 2011 at 6:29 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Using a relay makes it easier to use then a switch.
  6. Sep 21, 2011 at 7:12 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I am just finishing an install on a Pioneer AVH-P3300BT.
    You can use a toggle switch to operate the DVD bypass. A much cleaned install is to use a 12V relay that operates from the hot lead to an aftermarket amp. Then just switch ground from the relay contacts to the lead that you would connect to the parking brake sensor.
    The hot lead operated about 1 second after the HU is turned on and gives you the time delay you need.
