Finally finished my box.
Discussion in 'Audio & Video' started by Timfd024, Jan 14, 2013.
  1. Jan 14, 2013 at 8:54 AM
    Timfd024
    Timfd024 [OP] Active Member
    Tim
    Orlando, FL
    2012 DCab TRD Sport 4x4
    Billy 5100's and 1" rear block. Falken 265/65/18 Wild Peak AT. Audio--Kicker 6x9's and 6.5's hooked to 4ch Alpine. Audiobahn 8's subs to Kicker mono. JVC headunit.
    This is the end result of my first attempt at a molded fiberglass sub box. It came out pretty good. It was a little more difficult than I expected, fiberglass is some sticky $hi+. I used about a gallon of resin and 2 packs of mat/2 packs of cloth/3 yrds of strechy fleece. I made all cuts and recessed rings with a regular cheap jig saw. I didnt use a router because I wasnt worried about perfection, I knew this was going to be covered with carpet and that carpet hides a lot of mistakes. I used some audiobahn 8"s and ran them off of my old kicker 600.1 mono. Its a little too much amp for these speakers but I have them wired at 4ohm at 300rms to keep the speakers from frying. They sound and feel great. I highly recommend them for $40/ea they are kinda hard to beat.
  2. Jan 14, 2013 at 9:09 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Looks good from the picture! The build justifies better pics thought! Post them up!
  3. Jan 14, 2013 at 8:43 PM
    pinktaco808
    pinktaco808 Hot Steppa
    very clean
  4. Jan 14, 2013 at 8:57 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Clean install, those shallow mounts? Had a buddy with dual 8's in his dakota r/t they hit nice and tight.
  5. Jan 16, 2013 at 8:35 AM
    Timfd024
    Tim
    Orlando, FL
    Yes. The audiobahns are a shallow sub. The mounting depth is 3inch. They hit good for what they are. I have all kicker door speakers with a alpine amp and the these subs are a perfect compliment.
  6. Jan 16, 2013 at 5:41 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Sounds like you need more, im running three memphis amps, focal 3ways, and a polk ten at the moment in my single cab.. Eventually, when i finish lowering the truck i will build a rack and do a jlw710 then i should be happy
  7. Jan 16, 2013 at 8:24 PM
    Leonel
    Leonel Well-Known Member
    San Francisco,CA.
    2017 Super White DCSB TRDOR/6MT
    TC,Ext Kings,U402's,4:88's.Elocker rear,ARB front,etc..
    Looks great!! nice job dude
    And if you are happy with it then that's all you need
  8. Jan 16, 2013 at 8:27 PM
    TacoSkeet
    TacoSkeet 'MERICA
    Steven
    Memphis, TN
    03 DC Tacoma
    Very clean indeed
