FINALLY Fixed my vibes!!!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lonecountryboy, Mar 6, 2012.
  1. Mar 25, 2013 at 8:02 PM
    #61
    Fedz
    Fedz Well-Known Member
    Fady
    Everett, WA
    2013 Tacoma TRD OR DBL SB
    OME AAL,
    I strongly believe the vibration in the tacoma is due to the t case and the pinion are not on the same x axis. This is why when you install a one piece DS the a lateral angle at the t case is the same at the pinion but opposite hence canceling each other and also explains lateral angle at the u joint after the CB. But no angle at the pinion hence the vibs. Just my thoughts.
  2. Mar 25, 2013 at 8:08 PM
    #62
    Jetfixr
    Jetfixr What was I thinking??
    William
    Cocoa, Fl.
    Indigo Blue 4 door 6spd 07 4x4 TRD Offroad.
    TRD, filter and exhaust system. Red line hood struts, New frame Truxedo cover, Spyder pro headlights.
    I think I'd try to shove the shaft up someones ass at Toyota!!!
    Jet
  3. Mar 25, 2013 at 8:17 PM
    #63
    Fedz
    Fady
    Everett, WA
    OME AAL,
    I opened a case with Toyota and got extended warranty 8 year 125k miles for free but that did not fix the vibes.
  4. Mar 26, 2013 at 5:47 PM
    #64
    Fedz
    Fady
    Everett, WA
    OME AAL,
    What are your thoughts on if i get the front and rear drive shaft off of 99-2000 4 runner , lengthen the rear to fit the tacoma and at the rear u joint i swap it for the one off of the front shaft that mates to the t case , this way i do not have to drill the diff flange.
  5. Mar 26, 2013 at 6:34 PM
    #65
    Fedz
    Fady
    Everett, WA
    OME AAL,
    Is there any way around drilling the flange. I follow every step you mentioned except for the flange part. I understand the the drive shaft rear u joint is differet, if i get the front shaft off of the same 4 runner can i use the rear u joint the bolts up to the t case, this way i dot not have to drill the flange?
  6. Mar 27, 2013 at 8:15 AM
    #66
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    11 DC TRD OR 4x4 Pyrite Mica
    Very interesting! I just have a slight take off shutter after lifting it about 2". I've measured the angles of the joints till I'm blue in the face and tried adjusting the CB with many different shims and flipping it. Many other threads on this. Hmmm. I've gotten used to it but it still sucks.
  7. Mar 29, 2013 at 8:00 PM
    #67
    Fedz
    Fady
    Everett, WA
    OME AAL,
    I am also tired of messing with it, i contacted Tom Wood for a one piece drive shaft, it is $389 i am sure it will be money well spent.
  8. Mar 29, 2013 at 8:11 PM
    #68
    GreatBasinTaco
    GreatBasinTaco Well-Known Member
    Reno, NV
    2010 TRDOR MGM DCSB
    ARB bumper, OME 886's, Dakars, lr ucas, 1 piece driveshaft, softopper, 255/85 KM2, 60" hi-lift with custom mounts, thule roof rack, BAMF sliders, Allpro rear w/ dual swingout
    I put on a one piece shaft a few months back and have had no issues or vibes since. With the two piece after lifting I tried everything without any cures.
  9. Mar 29, 2013 at 9:46 PM
    #69
    Fedz
    Fady
    Everett, WA
    OME AAL,
    I would like to stay with OEM , but i find myself driving the truck very gentle to avoid feeling the vibs, which pisses me off. I asked Tom wood to build me a heavy duty drive shaft with Spicer joints, still waiting for a response. What do you have against the one piece?
  10. Mar 29, 2013 at 10:41 PM
    #70
    Fedz
    Fady
    Everett, WA
    OME AAL,
    I heard some bad reviews about Tom wood DS but did not think much of it, i am in WA , probably will hit my local drive shaft shop.
  11. Mar 29, 2013 at 10:43 PM
    #71
    Fedz
    Fady
    Everett, WA
    OME AAL,
    What do you recomend a one piece 2 joints or a one piece cv ?
  12. Mar 30, 2013 at 1:18 AM
    #72
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Just remember to make your pinion end u-joint run at near 0*
  13. Mar 30, 2013 at 7:12 AM
    #73
    GreatBasinTaco
    Reno, NV
    2010 TRDOR MGM DCSB
    You can go with double cardan, they tend to be a littlle more forgiving with minor vibes, but the wheel base of these trucks is long enough that single u joints at each end will work as well. I opted for single joints and have no issues.
  14. Mar 30, 2013 at 7:59 AM
    #74
    HB Taco
    Curt
    What kind of DS did you go with? Is it custom? can you provide more details and maybe pictures?
  15. Mar 30, 2013 at 8:12 AM
    #75
    GreatBasinTaco
    Reno, NV
    2010 TRDOR MGM DCSB
    I went with a custom ($380 from local shop). I will take pictures today. But basically it's just over 67" long at ride height with spicer 1330 sealed u joints. The slip spline allows for about 2" of extention and compression, which with my dakars is more than enough.
  16. Mar 30, 2013 at 8:18 AM
    #76
    GreatBasinTaco
    Reno, NV
    2010 TRDOR MGM DCSB
    Also, this is about as long as you can go with a single driveshaft. This is not a safe option for DCLB.
  17. Mar 30, 2013 at 9:49 AM
    #77
    Fedz
    Fady
    Everett, WA
    OME AAL,
    So what do i ask for at the drive line shop, i know double cardan , and give them the measurements, what else 1330 or 1350 joints?
  18. Mar 30, 2013 at 10:06 AM
    #78
    GreatBasinTaco
    Reno, NV
    2010 TRDOR MGM DCSB
    the shop will use the best u joints for the application. They may also give advice of double or single cardan. you could ask them also.
  19. Mar 31, 2013 at 7:55 PM
    #79
    Fedz
    Fady
    Everett, WA
    OME AAL,
    What do you guys think about a vibration damper between the carrier bearing and the cross member? That should sure reduce the feeling of the vibration
  20. Mar 31, 2013 at 9:08 PM
    #80
    Fedz
    Fady
    Everett, WA
    OME AAL,
    i was thinking one of these, but i will take your advice and not do it
