Finally found a great axle! Now the small but important questions!?
Discussion in 'Solid Axle Suspension' started by Eurotarded, Apr 3, 2019.
  1. Apr 3, 2019 at 1:45 PM
    Eurotarded
    Eurotarded [OP] Member
    Levi
    2002 Toyota Tacoma ex cab Trd 4x4 auto
    Hey guys. With all the info y’all have given it has helped me narrow it down to the waggy d44 axle. Found a guy on fb with the axle and fortunately he also had the sas kit minus shock hoops and leafs and trans mount. So now my only question is about the pinion and caster angle. Anyone have the required angles for the pinion and the required angle for caster? If it helps I’m planning on doing the three inch lift waggy from springs to match the 36” Chevy rear leafs. Thanks in advance!! You guys are awsome and quick with helping everybody out!
  2. Sep 17, 2019 at 6:25 PM
    Pdugan6
    Pdugan6 Well-Known Member
    Patrick
    Sunnyvale California
    3 link solid axle 2011 Tacoma 4x4
    6-10degrees
