Finally getting my lift. Just a few questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 14TacoStorm, Dec 26, 2015.
  1. Dec 26, 2015 at 5:58 PM
    14TacoStorm
    14TacoStorm [OP] Member
    Queens/Longisland
    14 TRD Sport
    Hey guys ive been reading the forums for a while trying to do as much research as possible before I ask any questions. But some things I'm still confused on. The kit I'm getting is a 3 in lift with bilstein coil overs and toytec add a leafs from toyteclifts.Com
    https://toyteclifts.3dcartstores.com/mobile/3-lift-kit-with-Bilstein-5100-Front-Coilovers_p_364.html
    1. Will this kit give me an actual 3 inch lift?
    2. Will I need new uca's extended brake lines or sway bar relocators?
    3. Is this the right lift for me? I do all highway driving and very very mild off road driving in private property. This is mainly for looks and maybe a little better than stock performance when I'm driving on my property.
    BTW I have a 2014 double cab trd sport. With 265/70/r17 nitto trail grapplers
    ThanKS in advance for any input and sorry if these questions have been answered in previous threads. I've read so many conflicting opinions I'm not really sure. Maybe someone who has or had this set up can point me in the right direction.
  2. Dec 26, 2015 at 6:07 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Yes UCAs.
    No brake lines.
    No sway bar mod.
    Work for you? Who am I to know?
    You'll get looks and a little performance. Better than stock? Will be stiffer for sure.
  3. Dec 26, 2015 at 6:08 PM
    timhom19
    timhom19 Well-Known Member
    tim
    Beaumont, Ca
    2010 DCLB
    I'm no expert but with the bilsteins that gives u 2.5 inch lift and added toytec Springs will give u a true 3 inch lift a buddy of mine has that setup. He did get new uca's because they are recommended for anything lifted 3 inches or more. It's a good setup so should work for you.
