Finally going to get new tires... What size?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by airwingch46, Jul 26, 2010.
  1. Jul 26, 2010 at 5:18 PM
    airwingch46
    airwingch46 [OP] Member
    I have a 2009 4x2 access cab. What are the largest tires I can put on the 15 in steel stock rims? Thank you in advance.
  2. Jul 26, 2010 at 5:20 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
  3. Jul 27, 2010 at 8:49 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    I wouldn't go any larger than the 225-70x15s I use for snow tires. Taller tires -- 235-70x15 puts you into "permanent overdrive" and the 235 is a bit too wide for the standard wheel.
    I went to a 235-60x16 on a 6.5-inch alloys for my summer wheels.
    Shop at TireRack. Their computer will help you avoid mistakes.
