Finally Got a Tacoma And I Need Your Help!
Discussion in 'New Members' started by Rustytaco03, Nov 17, 2017.
  1. Nov 20, 2017 at 9:56 AM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    What's a good grease to use? Or better yet, what properties should we look for in a good protective grease/oil?
  2. Nov 20, 2017 at 3:29 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Yeah, removing the bed makes it easier and allows you a better access to the frame, allowing you to to do a better job removing rust. The bed is not to hard to remove, just four bolts, thena few friends or neighbors to put it aside
    Any grease that will not completely dry over time. If you want to do it yourself, Fluid film is a perfect candidate for this. It never dries and isn't sticky and messy after being applied. Use this with a 360° spray wand to do the inside of the frame and you're good to go. Of course, you must rustproof your truck every one or two years, depending on the treatment, to keep maximum protection against rust.
    An oldshool trick is to use used engine oil (NO brake oil/fluid, as it attracts and absorbs moisture) or tractor grease.
    But grease is a better choice because it will not drip off and is less messy
    InfernoTonka[QUOTED] likes this.
  3. Dec 4, 2017 at 6:33 PM
    silverbullet02
    silverbullet02 Well-Known Member
    Cole
    Minnesota
    2002 Reg Cab 2.7 5MT 2013 Access Cab Baja 6MT
    Check out my builds! ----->
    Welcome to TW!
    Looks like your 2003 is nearly identical to my 2002 except for the year and mileage! As I am also from MN, my truck's frame looked even worse (meaning: not a speck of black paint was left that I could find) but I had it welded and it has since held up great! No body shop would do it due to insurance reasons, but my private guy was more than happy to assist! Check out my build, it has detailed pictures of where the frame was welded. I'm assuming your's was/is rusting in the same locations as mine.
  4. Dec 5, 2017 at 9:23 AM
    JonnyBstrick
    JonnyBstrick Well-Known Member
    Jonathan
    Denver, CO
    2001 Tacoma Xtracab SR5 - 5 speed - TRD Supercharger
  5. Dec 6, 2017 at 1:57 PM
    Rustytaco03
    Rustytaco03 [OP] Member
    Thanks everyone for your input!
