finally got an exhaust
Discussion in '1st Gen. Tacomas (1995-2004)' started by RAT PRODUCTS, Jun 24, 2010.
  1. Jun 24, 2010 at 7:36 PM
    RAT PRODUCTS
    RAT PRODUCTS [OP] Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Opted for the JBA fully stainless cat back. $300 and a lifetime warranty. The muffler is straight through and the only bends in the system are over the axle. Pretty easy install, the pipes fit real tight so it was hard to ram together under the truck. I used RTV to ensure no leaks. The tip comes out at a 45 degree angle, but doesn't stick out very far.
    Sounds mean. Definitely more like a real truck, no V8 tho. No resonance in the cab while cruising but you sure hear the growl when you accelerate. My butt dyno says I gained some torque. All in all, this is an impressive exhaust for the price.
    http://www.youtube.com/watch?v=jV2VHru8HL0
  2. Jun 24, 2010 at 8:45 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Cangrats!!! :)
  3. Jun 25, 2010 at 6:24 AM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    Good choice, that lifetime warranty sounds pretty nice :D
  4. Jun 25, 2010 at 10:17 AM
    Boosted17
    Boosted17 Well-Known Member
    Cliff
    Florence, Ky
    Looking for a new Toyota Truck.
    2006 Corvette Z51 M6. Best mod ever!
    Got any pictures of it? Would like to see how it looks. Sounds like a great deal!
  5. Jun 25, 2010 at 4:59 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I'll get some pics this weekend sometime.
  6. Jun 25, 2010 at 5:23 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    My butt dyno says I gained some torque. All in all, this is an impressive exhaust for the price.[/quote]
    ok,good deal.now whats a butt dyno?......explain.
  7. Jun 25, 2010 at 6:01 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    ok,good deal.now whats a butt dyno?......explain.[/QUOTE]
    People around here like to judge our mods by if we feel any more power after the mod compared to before. Basically how much force is put on your butt in the seat tells you if you have a lot of power or a little. I can tell it seems more explosive from a stop and it even tries to break the fresh new tires loose flooring it from about 3,500 RPM in first gear. That isn't bad.
  8. Jun 25, 2010 at 6:28 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    People around here like to judge our mods by if we feel any more power after the mod compared to before. Basically how much force is put on your butt in the seat tells you if you have a lot of power or a little. I can tell it seems more explosive from a stop and it even tries to break the fresh new tires loose flooring it from about 3,500 RPM in first gear. That isn't bad.[/quote]
    oh,i get it:D
  9. Jun 25, 2010 at 9:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :eek: Isn't that going to void your warranty. lol
  10. Jun 26, 2010 at 5:13 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Warranty? My truck hasn't had a warranty for years. And if something breaks or wears out, it's time for an upgrade.:D
  11. Jul 27, 2010 at 8:20 PM
    The Happy Idiot
    The Happy Idiot Active Member
    Upstate NY
    01 V6 4x4 SR5
    Toyota was nice enough to give me a new frame. JBA cat-back, aFe dry drop-in w/ deckplate, Bilstein 5100's all around, Timbrens, Alcan 5-leaf packs, OME 881's, linear clutch pedal return spring (best $3.49 I ever spent)
    I also slapped a JBA cat-back on with similar results. 'Twas a good deal, it seems.
  12. Jul 28, 2010 at 3:12 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    anyone know how they sound compared to a magnaflow cat back?
  13. Jul 28, 2010 at 6:27 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    No idea, but I've heard the magnablow is raspy so that's why I got the JBA. No rasp and it sounds great WOT, but pretty quiet cruising. Should be a little deeper when I get my CAI.
  14. Jul 28, 2010 at 7:28 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    Where did you purchase this system?
  15. Jul 28, 2010 at 7:30 PM
    malander
    max
    01 limited trd 4x4
    awesome i guess i just changed my mind... and saved a hundred bucks thanks
  16. Jul 29, 2010 at 6:57 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Got mine on autoanything.com for under $300 when they ran 20% off.
  17. Aug 2, 2010 at 2:29 PM
    malander
    max
    01 limited trd 4x4
    any sound bites of the 3.4 and jba? ive searched everywhere and cant seem to find one
  18. Aug 2, 2010 at 3:42 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
  19. Aug 2, 2010 at 5:37 PM
    ETaco23
    Evan
    PNW
    were you in nutral? Ive noticed that it sounds different or better when in neutral. :)
  20. Aug 2, 2010 at 5:42 PM
    malander
    max
    01 limited trd 4x4
    im sold
