Finally Got my new Shoes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtm1135, Jun 7, 2014.
  1. Jun 7, 2014 at 8:10 AM
    jtm1135
    jtm1135 [OP] Member
    First off huge thanks to all the posts on here that ultimately sold me on my tires, after reading through a lot of threads i finally got the setup that required NO TRIMMING just removing the splash guards an guards in front of the front tires:
    My Setup
    275/65r18 Goodyear Duratracs
    18x9 Fuel Maverick D538
    Bilstein 5100's Front & Rear
    Fronts set at 1.75 Stock Coils
    Stock UCA's
  2. Jun 7, 2014 at 8:26 AM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Looks good!
  3. Jun 7, 2014 at 8:30 AM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    Looks good. I like the black on white and that the wheels have some aluminum showing
  4. Jun 7, 2014 at 12:37 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    What did you put in the back as a lift, do you run the stock leave springs? Looks pretty level
  5. Jun 7, 2014 at 2:38 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I like those wheels. Looks sharp.
    Did you add some hub-centric spacers?
  6. Jun 7, 2014 at 6:10 PM
    jtm1135
    jtm1135 [OP] Member
    Thanks guys
    @flowin stock springs no change to the rear except the billies
    @thomasmore66 negative no spacer was needed I think since it was 4.5 or 5 back spacing with a 0mm offset has something to do with not needing spacers
  7. Jun 7, 2014 at 6:14 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    I need some! :(
    Looks good!
  8. Jun 7, 2014 at 7:08 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Truck looks great!
    But, you're going to regret removing the mud flaps I think. Those tires are going to pick up stones...
  9. Jun 11, 2014 at 6:44 PM
    MillerTime07
    MillerTime07 New Member
    Bradley
    Augusta, GA
    2012 Tacoma TRD Sport
    Anytime Fog light Mod, LED Tag lights, 2.5 inch Leveling Kit, 15% tint and 5% strip on windshield.
    Looks good. I plan on going with black 18s later on
  10. Jun 24, 2014 at 8:30 PM
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    jtm... Looks awesome! I am looking at those wheels too. I am really curious to know if yours are -12 offset (= 4.5" backspace) or 0 offset (=5 inch backspace).
  11. Jun 25, 2014 at 6:01 AM
    jtm1135
    jtm1135 [OP] Member
    Cmbondo..i got 0 offset i had saw some post on here saying the closer to 0 the better not sure if thats actually legit but hey its working for me
  12. Jun 25, 2014 at 6:42 AM
    1stTruck
    1stTruck Well-Known Member
    Jim
    South Carolina
    PreRunner
    Billies 5100's front set to 1.75 plus 1/4 taco lean spacer. Rears Billies plus AAL for a 2" leaf. 265/75/16 BGF's. Double din Kenwood stereo w/bluetooth and steering wheel controls and JBL speakers front & rear. Heavy duty battery. Billet grill blacked out. K&N air filter and MBRP cat-back. Just tuned it up new plugs and new front brake pads. Steel powered coated tailgate cap. Billet Grill painted black & factory roof racks. Oh new head lights thanks to toyota.
    Nice. :taco: Did you use a 1/4 spacer on top of the driver's side spring to level the taco lean? And did the 1.75 level the truck front to rear or are up a little higher in the front? Truck looks great.
  13. Jun 25, 2014 at 6:45 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Great looking truck!
