finally got the TRD supercharger and 7th injector kit done
Discussion in 'Texas' started by 03TRDtacotrucker, Sep 27, 2013.
  1. Oct 31, 2013 at 12:47 PM
    nigglewiggle60
    nigglewiggle60 Well-Known Member
    Nigel
    Oakhurst, CA
    2004 DC 4x4 TRD
    Rubber mats, Bluetooth.
    what performance upgrade to the transmission do you speak of?
    The only problems I have had, which I would like fixed so I can, is when I manually shift my transmission from 1st to 2nd to 3rd if I wait to shift right before red line you can hear a grinding noise like an automatic clutch is slipping.
    Is the "performance" upgrade to the auto just a pressure increase to make the transmission shift harder, or is it to relieve built up pressure?
  2. Oct 31, 2013 at 12:55 PM
    zacksblacktaco
    zacksblacktaco Well-Known Member
    west virginia
    06 trd sport access
    AEM CAI Throttle body spacer Borla cat back exhaust Doug Thorley long tubes RCD 4.5 anzo halo projectors with 4300k hids 12000k hid fogs T-rex stainless mesh mesh grille kit in pro car wear LED taillights & 3rd brake LED reverse lights LED license plate lights LED dome & map lights all Kicker speakers with 15 inch L7 subwoofer Jensen 7inch flipout headunit Trd sport seatcovers Re-badged red Tacoma
    my guess is he got a valve body upgrade from IPT
    runs cooler, shifts faster, ect...
  3. Oct 31, 2013 at 1:08 PM
    DHwreckage
    DHwreckage Well-Known Member
    Boulder, CO
    Moby Dick (FZJ-80)
    You ever get that WOT issue fixed, sounds like you need to dick with the tuning a bit. do you have an AFR gauge? WOT should be open loop so idk if it would be an AFR issue after all! if you do anything get the map3 ecu instead of the AEM Fic. have the stock ecu run your stock 6 injectors and have teh map3 ecu run the 7th injector. i have heard the map 3 is pretty easy to tune!
  4. Nov 1, 2013 at 12:01 PM
    nigglewiggle60
    Nigel
    Oakhurst, CA
    2004 DC 4x4 TRD
    how much to upgrade transmission and can a normal transmission guy do the work?
  5. Nov 1, 2013 at 12:17 PM
    BamaToy1997
    Bill
    Navarre, FL
    ??? A grinding noise like an automatic clutch is slipping? No such thing. If there is a grinding noise then you probably have some issues with the planetary gears. Auto clutch slippage does not make a noise other than RPMs going up.
  6. Dec 31, 2013 at 1:31 PM
    03TRDtacotrucker
    03TRDtacotrucker [OP] No Road. No Problem.
    Alex
    North Richland Hills, TX
    03 SC double cab TRD SR5 4X4
    TRD supercharger, URD 7th injector, Map 3 ECU, 2.2 URD pulley, Doug Thorley headers, Bear River tru performance hi flow cat, 18" Magnaflow muffler, 6" fabtech lift, 33" Goodyear wrangler tires, the old all pro tube rear bumper, ARB front bumper with smitty built 8k winch, pro comp krawlers 87 series wheels, roof rack, 60" hi-lift jack, K&N intake, grey wire mod, front and rear diff breather mod, G2-performance 4.56 gears w/ royal purple oil, red top optima battery, PreRunner Tiregate with full size spare, Radflo front coilovers, Custom home made front skid plate, rear bilstein 5150 series shocks, Elite sliders w/o kick, Camburg UCA, mech grill with old school TOYOTA logo, ash tray removal Cobra CB radio w/ Firestik - List as of 1-17-18
    To be honest I have no clue what all brand names they put in the transmission. I just told the performance shop to put in a beffy torque converty, valve body, gears and clutches lol. works great and shifts quick and pretty smooth for a performance build. specially under high load. Trans arent my area of specialties as you can see..
  7. Dec 31, 2013 at 1:34 PM
    03TRDtacotrucker
    Alex
    Cost me 2500.00 and im sure if you told the shop the performance parts you want that any shop could install, but the warranty is what they might get you on. Thats why I chose a specific transmission performance shop to do mine who has been doing trans for 26 years.
  8. Dec 31, 2013 at 1:39 PM
    03TRDtacotrucker
    Alex
    No it still likes to go lean on me at random times during pro longed boost. As long as i just do half throttle from a stop it has plenty of get up and gives me not fits. I still need to have it tuned, but just dont feel like puting anymore money into it right now since it still drives for the most part fine. I put the stock SC pulley back on for now till I get it tuned which seems to keep it from going Lean less often under boost.
  9. Dec 31, 2013 at 1:43 PM
    03TRDtacotrucker
    Alex
    yeah I hear alot of people saying that. I probably would have been fine not doing the Trans upgrade, but since it was already giving me a fit I just went ahead and did it. My trucks only got 120k miles on it... just a little less than yours lol.
  10. Jul 8, 2014 at 8:46 PM
    03TRDtacotrucker
    Alex
    so after having my wiring/ installation on the URD 7th injector checked out by my two mechanic buddies and now a performance tune shop no one could find any faults in the installation of everything. so i gave up with the URD setup and had the tune shop install an ECU map-3 setup with an AFR monitor that still uses the 7th injector from the URD kit. runs a lot better than the URD tuner only thing is the tune shop is having an issue with while under prolonged boost the ECU tries to creep the AFR from the 11's back up to stochi (14.7) which is really bad under boost. anyone know of a fix for this issue with a map-3 ECU setup? done some researching and havent come across a direct fix for this issue.... any suggestions? Also have been getting mixed answers on cruising AFR.. the tune shop has it set to cruise in the 17:1 AFR?? they keep telling me that as long as its just cruising at this AFR that its not harmful to the engine. truck goes immediately to the 11-12's as soon as it hits boost, but i was wanting some other input if people think this is a safe cruising AFR for a tacoma?....
  11. Aug 19, 2014 at 6:54 PM
    03TRDtacotrucker
    Alex
    Just an update if anyone cared to know. the issue with the creeping AFR under boost was due to a faulty AFR sensor on the truck. replaced it and retuned and problem gone. since then I've added Doug Thorley headers, custom stainless steel exhaust with eastern hi flow cat and magnaflow muffler. Gained 20 HP and torque with the new setup. current dyno put me at 229 HP and 241 Torque to the wheels with 35" KM2 tires and 4.88 gears. so close to 290-300 at the flywheel more than likely. The exhaust helps A LOT with drivability. cruises effortlessly on the highway now and gas mileage is about 2 MPG better than before so at about 16 MPG now. if you supercharge it, full header back exhaust is a must, don't wait like I did.
    10thMTNgrunt, Freeflight7 and Large like this.
  12. Jan 12, 2015 at 10:31 PM
    mikenblue
    mikenblue Member
    College Station, TX
    Thrush Muffler Doug Thorley Headers Deckplate Mod w/ Airaid intake tube and AFE filter OME Lift kit
    Oh you are from richland hills? we should meet up sometime! would love to see the truck!
  13. Jan 23, 2015 at 12:00 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    Op, I'm looking at doing the 7th injector kit next week on my T100. Are you still against it? What would you recommend starting fresh?
  14. Aug 3, 2016 at 10:03 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    AFR sensor? My bad air/fuel ratio sensor will have to look into that, what does WOT mean though My truck is just lagging around 2.5-3.5K RPMS. Plus the computer is sending me a knock sensor code.
  15. Aug 7, 2016 at 7:04 PM
    #35
    Luke01
    Luke01 Well-Known Member
    Luke
    Dallas, TX
    2012 Tacoma DCSB MGM lifted dented and armored
    Grillcraft Grill, Leer 100q top, 5100's on four corners, OME 885x up front, OME Dakars with add a leaf in rear, Lighting, a mix of Rigid and Chinese LED's, US Off Road hidden winch front bumper, SOS offroad conceprs skids, and rear bumper with swing out
    WOT is wide ooen throttle
