Finally joined since I'm having trouble with my taco
Discussion in 'New Members' started by Toyfam209, Sep 23, 2016.
  1. Sep 23, 2016 at 1:59 PM
    Toyfam209
    Toyfam209 [OP] Member
    '00 taco manual 4x4 TRD
    I have a 2000 Tacoma 5 speed manual v6 Trd .
    Burning a lot of engine oil have to fill a quart every time I go for a long drive .. Have 326k original engine.. No rebuilds (yet).. Was thinking should it need a rebuild now or what are you guys suggesting .. Thanks
  2. Sep 23, 2016 at 2:11 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to TW! Depending on what weight oil you are running, you could go to a heavier weight to help slow oil loss as a very temporary mitigation strategy. However, if you are certain you are burning it, with that kind of mileage it isn't worth doing any partial fix IMO. If it gets you from A to B, rebuild when you have a good opportunity.
  3. Sep 23, 2016 at 5:13 PM
    Toyfam209
    It still runs pretty well.. Still drive it camping(3hrs/6hrs round trip) . I only take it to Toyota for oil change . Truck is stock just on some 285/70/16 mud tires .. I was hoping it was just some valve seals .. But your the second person that said for a rebuild . Thanks for your opinion though . Appreciate it .
  4. Sep 23, 2016 at 5:24 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Oil is cheap
  5. Sep 23, 2016 at 6:57 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
  6. Sep 23, 2016 at 7:01 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    When was the last time you replaced the PCV valve?
  7. Sep 23, 2016 at 7:02 PM
    Toyfam209
    I hope I am due for an oil change but I'm still needing to add a quart weekly ... But what type of oil should I use ?
  8. Sep 23, 2016 at 7:02 PM
    Toyfam209
    It's been a while ... Since new p c v
  9. Sep 23, 2016 at 7:03 PM
    pudge151
    Sean
    Connecticut
    Try changing it. Cheap and easy. If not I say just keep adding oil
  10. Sep 23, 2016 at 7:09 PM
    Toyfam209
    Yup sounds like a plan next weekend gotta go hunt this weekend
  11. Sep 24, 2016 at 8:20 AM
    KenLyns
    Belly of the Beast
    PCV valve should be replaced every 40,000 miles or so. Clogged PCV valve can cause the crankcase to overpressurize, leading to burning oil and leaks. Cheap part to replace.
    It's OK to mix synthetic and conventional. It's more beneficial to add the same brand of oil as what's already in the crank case so the additives don't work against each other.
    Typically the first casualty of heavy oil consumption is poisoned catalytic converters ($$$$), so it's important to address the issue quickly.
  12. Sep 24, 2016 at 10:41 AM
    Toyfam209
    Catalytic convert. Been replace less than 100k from factory Toyota . I hope it's not that I spend 3k on it already ..
  13. Sep 25, 2016 at 11:23 AM
    KenLyns
    Belly of the Beast
    ^Casualty, as in burning oil can lead to damaged cats. Not the other way around.
  14. Sep 25, 2016 at 11:39 AM
    Toyfam209
    Is there a good thread about how to change p c v.. Just wanted to refresh my memory been ages since I had done one .
  15. Sep 25, 2016 at 11:40 AM
    Toyfam209
    And should anything else be Andressed wyile I'm doing it
  16. Sep 25, 2016 at 3:25 PM
    KenLyns
    Belly of the Beast
    It's on bank 1 next to the plug wires, very easy to access. Apparently the part is easy to break, so have a replacement PCV valve ready before you remove the existing one.
