Finally killed that retched leaf spring squeak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Floridahunter, Sep 14, 2016.
  1. Nov 16, 2016 at 6:58 PM
    #41
    dutchjim
    dutchjim Well-Known Member
    Jim
    San Diego
    Thanks Smitty, again.
  2. Nov 16, 2016 at 8:48 PM
    #42
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    Maybe better 'cuz it don't kill rubber or plastic... but still likely won't last 5 minutes into your ride.
    If one must insist... Silicone spray might quell that squeak for 5 minutes after being applied.
    But don't expect that satisfaction to last long !? Lol
  3. Nov 17, 2016 at 12:33 AM
    #43
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Factory bolt is 9/16 but that bolt required 'slight' boring out the oem hanger. it was just a hair too big. i made it fit, and it fits the bushings perfectly. might wanna give 1/2 a try but technically the 9 16 is the correct size
  4. Nov 17, 2016 at 8:06 AM
    #44
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    TRDOBSESSED and Pinche_tacos like this.
  5. Nov 17, 2016 at 10:42 PM
    #45
    ProForce
    Anthony
    Alaska
    Company? Link?
    What grade is the bolt ?
  6. Nov 18, 2016 at 6:49 AM
    #46
    Crikeymike
    Jax Beach, Florida
  7. Nov 18, 2016 at 7:11 AM
    #47
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Didn't read it all but I'm sure it's been mentioned that wd40 is not lube, it's a penatrating oil
    KB Voodoo likes this.
  8. Nov 18, 2016 at 7:21 AM
    #48
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  9. Nov 18, 2016 at 7:29 AM
    #49
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
  10. Nov 18, 2016 at 8:27 AM
    #50
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    WD40 was born out of our space program. It was invented to prevent rust on the surface of the early Atlas launch vehicles. The fuel tank of the Atlas was fabricated out of stainless steel. In the presence of the Florida humidity it would rust quickly. WD40 prevented this from occurring.
  11. Nov 18, 2016 at 8:31 AM
    #51
    scornwel
    Fort Worth
    None
    I do too. I use it on my mountain bike....Good stuff.
  12. Nov 18, 2016 at 8:54 AM
    #52
    BizzyB726
    BizzyB726 Well-Known Member
    Brandon
    New Jersey
    2012 Black Tx Baja
    In regards to the squeak fix...I can't find it now but I remember reading on TW about someone putting strips of bicycle tubing between each leaf and seemed to have fixed the sqeak issue.
    I personally haven't tried it yet but i plan on it, before replacing them all together for AAL.
    If i remember correctly...
    Jack up truck to take tension off springs.
    Cut bicycle tubing to desired length and width (Not exceeding past the points of contact between metal on metal)
    Pry apart springs.(With Crowbar)
    Slide pieces of rubber tubing between each spring. (Not sure if any adhesive is necessary or not to keep them in place. Maybe the weight/tension is enough)
    Lower truck and hope for no squeaks!!
    Hope this helps for anyone that was not aware of this option.
  13. Nov 18, 2016 at 11:27 AM
    #53
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I would think that rubber would either work it's way out or just tear from the springs movements...! On other trucks I've owned, I used pieces of old forest fire-fighting hose...No rubber.. the hose is made to sweat and therefore not burn in a fire.... I just soaked the shit outta a few pieces of that stuff and slid them in there.... Worked for me..!! This was not extreme off roading though..!
    BizzyB726[QUOTED] likes this.
  14. Nov 18, 2016 at 12:39 PM
    #54
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
  15. Nov 18, 2016 at 12:40 PM
    #55
    over60
    Muskoka, Ontario
    Same here man... Those are real nice... did not they existed, like you..!!
  16. Nov 18, 2016 at 1:15 PM
    #56
    mpm
    mpm Well-Known Member
    You've got to be kidding me.... I find this just as I'm about to pull my leaf springs off and add plastic leaf liners. My squeaking appeared after adding an AAL, so I assumed it was the change of pressure in the individual springs that allowed dirt to work itself in. I've been dealing with it ever since, and would sometime spray some PB Blast all over the springs to give myself a few weeks of relief.
    I guess I'll still go forward with the leaf liners and report back with the outcome. If it doesn't stop the squeaking, I'll install the greaseable bolts in the front bushings.
  17. Nov 19, 2016 at 9:03 AM
    #57
    Shelf Life
    Rob
    Central Oregon
    I cant believe squeaky leaf springs are still a thing with new gen Tacoma's. You would have thought they had it handled by now. Maybe they will come up with a non-squeak edition for $3 K more.
  18. Nov 19, 2016 at 9:08 AM
    #58
    Clearwater Bill
    Billy
    Largo Florida
    While I agree, its worth noting this is not just a Tacoma issue. Every leaf vehicle I've owned has squeeked. Its why you can find so many 'solutions' in the market.
  19. Nov 19, 2016 at 9:28 AM
    #59
    Shelf Life
    Rob
    Central Oregon
    Yeah, I've had a few trucks over the years, but none of them started squeaking right out of the box like my Tacoma. That was ten years ago. I'm just a tad surprised it still happens with the new rigs.
  20. Nov 19, 2016 at 9:31 AM
    #60
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    id pay 3k today to get rid of all my squeaks and rattles. it would take new leaf packs with graphite paint, newly engineered clutch pedal assembly, new drivers door seat belt adjustment thingy, new front rad support bushings, and a few door seals.
