Finally killed that retched leaf spring squeak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Floridahunter, Sep 14, 2016.
  1. Apr 2, 2018 at 7:03 PM
    #81
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Between all the springs and in the shackles.
    I'm not sure if my squeaks came back yet, it's still too cold to drive with the windows open.
  2. Apr 2, 2018 at 10:34 PM
    #82
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Where the leaf springs bolt to the hangers
  3. Apr 19, 2018 at 6:13 PM
    #83
    Guccimane
    Guccimane Member
    And that's all you did? Did you add any lube, grease or anything else? '
  4. Apr 19, 2018 at 6:20 PM
    #84
    Guccimane
    Guccimane Member
    Can you provide any instruction on how to install the greasable bolts?
  5. Apr 19, 2018 at 6:21 PM
    #85
    ProForce
    Anthony
    Alaska
    Well i got a brand new bushing kit for my leaf springs. Nothing special just the ones from allpro that come with my leaf pack. But i wanted to start fresh. So after putting new bushings and replacing the factory bolt with the greasablge ones, then just pumped them up with grease and that's it. I put a little fresh grease every couple months when they start to squeak. The noise guess away within about a day off driving when the new grease works it's way in there
  6. Apr 19, 2018 at 6:31 PM
    #86
    Guccimane
    Guccimane Member
    Oh okay. Do you have to lift the truck to pull that bolt out?
  7. Apr 19, 2018 at 6:52 PM
    #87
    ProForce
    Anthony
    Alaska
    Yeah to take the pressure off the leaf pack
  8. Apr 20, 2018 at 6:33 AM
    #88
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    Yeah, take the old bolt out and put the new one in!! hahaha, it's more simple than you're making it out to be.
  9. Jul 26, 2019 at 8:41 PM
    #89
    Guigster
    Guigster Member
    Southern New Jersey
    4x4 SR5 Magnetic Gray Metallic
    WeatherTech® FloorLiner™ DigitalFit® (46021-1-3), WeatherTech® Side Window Deflectors (82389)
    I recently had my frame replaced under warranty. After getting it back, my leaf springs began to squeak like crazy. Took it back for a leaf spring silencer kit. However, AFTER getting the truck apart, they realized that the silencer kit was for the old leaf springs that were replaced under a different warranty a few years back. There is not silencer kit for the new design. I put the chances at 0% we ever get one. Going to have to go with the self-lube method. Seems like the consensus is that T-9 spray. Glad I checked here. I was ready to WD-40 those things up.
  10. Jul 27, 2019 at 6:58 AM
    #90
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    The greasable bolts do nothing on factor leaf springs.They use rubber bushings which are frictionless unlike aftermarket poly ones. Same thing for spraying lubricants on the factory bushings. The only say that would stop squeaking temporarily is by inadvertently getting lube on the leaf spring friction pads which should be greased.
  11. Jul 27, 2019 at 9:29 AM
    #91
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  12. Jul 27, 2019 at 11:01 AM
    #92
    Joisey
    Joisey Well-Known Member
    Spray the bushings with Ruglyde.
    OnHartung'sRoad likes this.
  13. Jul 27, 2019 at 11:12 AM
    #93
    eurowner
    eurowner Duke Sky
    Scoty
    At 27k, last month mine started squeaking. I lifted the back end up, let the rear axle droop all the way and power washed the leaf pack. No more squeaking. No lube.
  14. Jul 27, 2019 at 11:38 AM
    #94
    OnHartung'sRoad
    Go out on dusty roads much?
  15. Jul 27, 2019 at 11:41 AM
    #95
    OnHartung'sRoad
  16. Jul 27, 2019 at 11:51 AM
    #96
    eurowner
    eurowner Duke Sky
    Scoty
    From time to time.
  17. Jul 27, 2019 at 11:55 AM
    #97
    OnHartung'sRoad
    Ah, dusty roads always caused it to my truck until the bushings were lubed right.
    Hate that squeak- I don’t mind it while driving so much, but it has been the source of some pretty funny jokes after some nights in the RTT:D
    eurowner[QUOTED] likes this.
  18. Jul 27, 2019 at 2:09 PM
    #98
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    My truck squeaks occasionally when I get out. Started after it went mudding. Anyway, I sprayed the leafs down with Bosheild T9 earlier. Didn't hear any squeaks the 2 times I've gotten out since. Time will tell.
  19. Jul 29, 2019 at 11:22 AM
    #99
    Joisey
  20. Jun 2, 2020 at 8:07 PM
    #100
    Sylviastaco
    Sylviastaco New Member
    Kenneth
    2017 Tacoma Off Road
    Nato style steel wheels and Toyo Open Country M/T (so far)
    What about silicone spray or a marine dry lube? I have the same fucking squeak. I was about to replace shocks.
    AmateurTaco1313 likes this.
