Finally killed that retched leaf spring squeak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Floridahunter, Sep 14, 2016.
  1. Apr 10, 2021 at 8:20 AM
    #101
    Mastiff37
    Mastiff37 Well-Known Member
    Tucson, AZ
    2011 Regular Cab 4x4
    Reviving this thread. For some reason my truck started creaking like crazy recently. I notice it driving in parking lots. But it seems like there are two things here, the leaf pack and the bushings. In my case it's sort of a lower pitched creaky groaning sound (like jumping on an old bed?). I'm 90% it's the bushings, not the leaf pack. Anyone have a solution though? My old Blazer has fancy aftermarket poly bushings with greasable bolts and it still does the same thing...
  2. Apr 10, 2021 at 12:12 PM
    #102
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I coated my leafs good with cosmoline...no squeaking back there yet.
    Steamy Longbottom likes this.
  3. Jan 23, 2023 at 8:25 AM
    #103
    1schoir
    1schoir Well-Known Member
    Freeport, NY
    2006 Red Tacoma SR5 Access Cab 5 speed..1995 Blue Tacoma Extra Cab 4 cyl 5 speed...
    Re-reviving an old thread... If you can isolate the source of the noise to the bushings, either front or back, spray a lubricant that does not disappear by evaporation but rather leaves a coating behind. The best one that I have found, which also does not attack rubber is made by Wurth. A can of their HHS spray is a tad expensive but it goes a long way. After spraying the bushings, if the noise does not go away, apply it to wherever there are two parts rubbing together (leaf, clamps, etc.). It does not wash away easily so the noise will stay away for a good while. PB B'laster penetrating oil lubricant also does not evaporate away, but it's not quite as good as the Wurth HHS. Both do a much better job than WD-40, which is NOT a lubricant.
    BizzyB726 likes this.
  4. Jan 23, 2023 at 8:28 AM
    #104
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i spray dry silicone on my leaf spring bushings/pads when they start to squeak. last time I did this it lasted about a year before i got another squeak.
    islesrule123 and BizzyB726 like this.
  5. Jan 23, 2023 at 8:31 AM
    #105
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    yea, those are the discs that start to squeak...
  6. Jan 23, 2023 at 8:34 AM
    #106
    1schoir
    Freeport, NY
    I guess you need some anti-squeak for the anti-squeak discs! :)
  7. Jan 23, 2023 at 8:49 AM
    #107
    islesrule123
    islesrule123 Well-Known Member
    New York
    2016 inferno Tacoma TRD off road
    Trd pro suspension trd pro grill
    This is my follow post
  8. May 4, 2023 at 6:00 PM
    #108
    Noelbnetz
    Noelbnetz Active Member
    2022 White Tacoma TRD Off Road
    Gonna have to agree with the boeshield t9 lubricant. Worked immediately when i sprayed it on my leaf spring end shackles, not the ubolt or near the rubber bearings. I was too lazy to take apart and clean the leafspring pads so i just sprayed it in between on both sides as best as i could. Literally in a few minutes, i did the squeak test by pushing down on the back of the bed a few times and the squeak was gone. Specially focusing on those circular pads that are in between each leaf spring. No idea how long its going to last but this made me a 100x happier knowing the squeak is not there at the moment. Thank you guys who first commented about this product!
  9. May 6, 2023 at 11:50 AM
    #109
    KillBill216
    KillBill216 Member
    21' 4WD SR DCSB
    16' Matte Black Alloy Wheels 265/70/R16 Cooper Discoverer Rugged Trek
    Fluid film did the trick for me!
  10. May 6, 2023 at 1:18 PM
    #110
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    Oil of Olay was old school.
