Finally Lifted!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ejewels, Nov 17, 2018.
  1. Jan 4, 2019 at 5:58 PM
    #181
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Trucks are wierd. I’ve talked to you before about the whole lift etc etc.
    3” lift rear and 2” lift up front. I have no shims and have no CB drop and ecgs and my trucks operates normal.
    I thought it would have been your duratracs because they are known to be hard to balance or most of the time I hear they are out of round from factory.
  2. Jan 4, 2019 at 6:10 PM
    #182
    runmc
    runmc Well-Known Member
    Ron
    DFW Texas
    2021 Army Green Tacoma TRD OR DCSB
    One Mod after another
    No it's not bad at all. I did it a couple of months ago. I have read a million different threads with a million different remedies. Crazy.:annoyed: Like he said - All trucks are different.
  3. Jan 4, 2019 at 6:24 PM
    #183
    SpeySquatch
    2016 TRD OR DCSB
    Didn’t I tell you this EXACT thing in the beginning because you were installing nearly the exact thing I currently run?
    I went thru all this BS myself including taking the driveline off and having it professionally balanced. Sometimes it’s best to trust people with experience...oh well, glad you got it figured out even if you went about it the hard way
    MattEcho, jsinnard and ruffridha9 like this.
  4. Jan 4, 2019 at 6:26 PM
    #184
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    Guessing what degree shims or if you need a carrier bearing drop is a crazy mans game. Very simple to drop the drive shaft and measure trans output shaft angle and pinion angle on rear diff. As long as the two propellor shafts are parallel with each other then the two other angles meantioned above just need to be within half a degree of each other to solve vibrations. Socket wrench and angle finder for $10 is all that is needed. Literally.
    SpeySquatch likes this.
  5. Jan 4, 2019 at 6:28 PM
    #185
    Dr. Emmett Brown
    And OP I've seen that pre-lift thread...those dudes are right, you ask a lot of questions...wait, you ask the same question a lot of times and in lots of ways. Lol.
    I'm glad you finally got the thingg figured out and you're happy with your lift. That's the end goal for us all :cheers:
    Cheers to the weekend
  6. Jan 4, 2019 at 6:38 PM
    #186
    ejewels
    ejewels [OP] Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    I was about to install the shims (had bought them originally just in case) and the first set of guys removed the driveshaft and said the vibes were still there so the shims wouldn’t do anything. That’s why I never installed them. But then again today, the dealership did the same thing and said the vibes did go away so then I had them do it. Long drawn out expensive story... but seems to be good now.
  7. Jan 4, 2019 at 6:46 PM
    #187
    ejewels
    CT
    The only thing I’m concerned about now is that they didn’t use bolt head lengtheners / collars so that with the shims installed the center pin bolt head sticks out more and fully seats into the axle. The tech said I should be ok along with the service advisor as enough of the bolt head was still showing to go in the hole. It was only a 1/8-1/4” though. I’m pretty sure the u bolts do the heavy lifting in that assembly but I might eventually get longer center pins and bolt head lengtheners/ collars for piece of mind. They said they stand behind the work. If my axle flies off they can buy me a whole new truck :)... the beauty of having the stealership do it.
  8. Jan 4, 2019 at 6:48 PM
    #188
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    It would have been only like $30 to buy the parts and try them yourself. Add a CB spacer, take it for a drive and repeat.
    New center pins are $5
  9. Jan 4, 2019 at 6:52 PM
    #189
    Dr. Emmett Brown
    What type of shims did they install? The ones that just slide in and are slotted or they took the center pin out and bolted in the shim to the rest of the pack?
  10. Jan 4, 2019 at 7:01 PM
    #190
    ejewels
    CT
    Pretty sure they have a hole in the center so not just slide-ins.
  11. Jan 4, 2019 at 7:10 PM
    #191
    Dr. Emmett Brown
    If they have a hole in the center then they took your pack apart and put the center bolt through the shim and tightened down the nut. you said you went with dakars? I'm quite certain the dakars center bolt allows for you to put another leaf on it (making it the heavy duty pack) AND a shim so you're definitely fine. As far as the u bolts, unless you only had like 5 threads showing passed the nut prior to putting the shim in, then adding a 1/4" shim still leaves you with a lot of thread on the ubolts. As long as they retorqued your ubolts, your axle/leafspring/rear tires/front seats/passenger side mirro/grille will be perfectly fine. Lol.
  12. Jan 4, 2019 at 7:14 PM
    #192
    SpeySquatch
    2016 TRD OR DCSB
    Just glad it’s all good. :thumbsup:
    ejewels[QUOTED][OP] likes this.
  13. Jan 4, 2019 at 7:16 PM
    #193
    ejewels
    CT
    The shims have some height to them... I’d say thick side is over 1/4” and the thin side maybe an 1/8”. I wasn’t concerned about the center pin length as much as how much of the bolt head sticks out on the bottom where it sits in the hole of the axle. Maybe as long as enough of it sticks out to partially sit in the hole is all that matters? Just to have something to catch onto the axle? I do know the u-bolts are what really hold things together.
  14. Jan 4, 2019 at 7:22 PM
    #194
    Dr. Emmett Brown
    If the shim was added to the pack the same amount of bolt head is going through the hole in the axle.
    Turd Hawg likes this.
  15. Jan 4, 2019 at 7:29 PM
    #195
    ejewels
    CT
    Honestly I don’t know. Theoretically if the hole in the shim is large enough it could just slip over the existing bolt head (like the slide ons do). I’m just gonna trust what these guys did. I brought it up numerous times as a concern and they said it’s all gonna workout and it’s long enough.
  16. Jan 4, 2019 at 9:15 PM
    #196
    SK808
    SK808 Well-Known Member
    Ewa Beach, Hawaii
    2017 Tacoma TRD OR DCSB 4X4
    Magnuson Supercharger, Kings w/Resi front and rear, ICON UCA, Allpro STD leaf pack, C4 Fab Hybrid Front Bumper, RCI Rear Bumper, X20 winch, All Pro U-bolt Flip Kit w/ wheelers bump stop, Method 701, 17X8.5 w/0 offset, BFG KM3 285/70/17, All Pro Sliders, TRD CAI, Spec-U exhaust, Total Chaos bed stiffener, RCI Skid Plates (all skids), Wet Okole seat covers, Diamondback tonneau cover, Grillcraft MX Grille, Husky front floor mats, Weather Tech rear floor mats, bed mat, various Baja Design lights, mobtown tailgate reinforcement plate, and a bunch of other stuff.
    I have the allpro standard duty leaf pack (roughly 3in of lift). I initially installed it with a CB drop spacer and no shim. I got really bad drive shaft vibes. I removed the CB drop spacer and it actually got better. It reduced the vibe tremendously, but the vibe was still there. I ended up adding the 3 deg shim to the leaf pack and no more vibes, rides super smooth.
  17. Jan 5, 2019 at 4:59 AM
    #197
    ejewels
    CT
    It’s amazing how these manufacturers don’t have easier solutions since this stuff is so common. I still don’t understand how one identical truck can have issues while another won’t. Stock for stock, same mods, etc.
  18. Jan 5, 2019 at 2:27 PM
    #198
    Taco1.1
    Taco1.1 Well-Known Member
    2018 TRD Off-Road
    Debadged, Kenwood 9905 Head Unit, Tinted Windows, Remote Start
    I've always assumed this had more to do with different people's tolerances for annoyances (vibrations, etc.) and also the varying ability/proper installation of backyard mechanics/independent shops. IE, Toyota probably builds a vehicle more consistently than the consistency of everyone's individual installations.
  19. Jan 16, 2019 at 9:53 AM
    #199
    dustxking
    dustxking Well-Known Member
    Update your thread first post so people doing this exact install can see exactly what you purchased including the shims. That would help greatly (myself included).
  20. Jan 16, 2019 at 9:55 AM
    #200
    ejewels
    CT
    I could do that, but many seem to not need the shims. Which is weird to me but apparently mfg tolerances are that different.
