Finally Lifted!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ejewels, Nov 17, 2018.
  1. Jan 17, 2019 at 10:42 AM
    #201
    lloverso
    lloverso Active Member
    Pa
    2018 Tacoma TRD Off Road
    ProComp 3/1 Nitro Level Kit Diff Drop Spacer 17x9 Method 312 -12 Offset 285/70/17 Nitto Terra Grappler G2
    I have the same exact vibration on decel at 25 mph and also around 65 mph on the highway. I only have a 1" block in the rear but am being told my pinion angle is out of spec. The stock leaf pack already came brand new with a small shim. So do I replace the flat 1" block with a 1 degree tapered block from low range off road or have the dealership install a 2 degree shim to replace the stock one? Thanks
  2. Jan 17, 2019 at 12:11 PM
    #202
    ejewels
    ejewels [OP] Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    I'm no expert, but I'd assume its a little more stable getting the tapered block...
