Finally Lifted!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ejewels, Nov 17, 2018.
  1. Nov 18, 2018 at 6:53 PM
    #121
    SpeySquatch
    2016 TRD OR DCSB
    It’ll do the trick. It’s ideal for these trucks
  2. Nov 18, 2018 at 6:56 PM
    #122
    ejewels
    ejewels [OP] Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    you scared me for a minute though... thought my packs were messed up only getting 2".
  3. Nov 18, 2018 at 6:57 PM
    #123
    ejewels
    CT
    BTW...toytec wants friggin $22 to ship those little shims. I gotta find another place.
  4. Nov 18, 2018 at 7:05 PM
    #124
    SpeySquatch
    2016 TRD OR DCSB
    Google 3 degree shims and go check Home Depot for the bolts
  5. Nov 18, 2018 at 7:11 PM
    #125
    tcjacado
    tcjacado Well-Known Member
    That was me and I have done it twice on my truck. Use c clamp to hold leaves together. Remove center pin, then slowly open the clamp to decompress the leaves if need be to insert add a leaf or what ever. Since you dont need to put anything in between them. Just remove center pin, slide shim in, put 8n new pin if old one isn't long enough and retighten. Then remove c clamp
  6. Nov 18, 2018 at 7:13 PM
    #126
    ejewels
    CT
    And you reused the U bolts?
  7. Nov 18, 2018 at 7:16 PM
    #127
    tcjacado
    I had longer ones to put in the first time. But I have reused mine now on 3 different configurations. So yeah it's ok to reuse them as far as I can see. Just make sure they stay tight. Recheck torque every couple of months until you figure out they aren't going anywhere. Mark with paint pen for quick reference
  8. Nov 18, 2018 at 7:27 PM
    #128
    ejewels
    CT
    OK thanks. Couple others said the threads break/twist so you can't resuse.
  9. Nov 18, 2018 at 7:29 PM
    #129
    tcjacado
    Add some loctite and I wouldn't worry to much.
    ejewels[QUOTED][OP] likes this.
  10. Nov 19, 2018 at 8:15 AM
    #130
    TacoSnacks
    TacoSnacks Member
    NJ
    2017 White Tacoma Limited
    OP, keep us posted on your progress. Im looking into the same lift for my 17 Limited 4x4. I was debating not doing the CB drop and going with just the shims. This thread is making me think I should stick with that decision... I'll be sure to follow-up once I get the lift on. Good Luck.
    ejewels[OP] likes this.
  11. Nov 19, 2018 at 9:35 AM
    #131
    tsmitty2661
    tsmitty2661 Member
    Tyler
    2018 Cement TRD Sport LB
    After Reading this I just had 3 degree shims 2-dayed so I can put them on when I do the AAL (1.5") wednesday. Didn't want to mess around with doing it twice lol
  12. Nov 19, 2018 at 9:48 AM
    #132
    ejewels
    CT
    I read you could get vibes with shims and no vibes without them. I think it’s truck by truck.
    tcjacado likes this.
  13. Nov 19, 2018 at 10:10 AM
    #133
    TacoSnacks
    TacoSnacks Member
    NJ
    True. In my case I'm thinking of deff doing the shims and if a CB drop is needed that's easier to do post lift rather than having to mess with dropping the springs again. I see so many mixed reviews on if the CB drop is even needed when adding a lift in the 2" and 3" ranges on the 3rd gens... We will see I guess.
  14. Nov 19, 2018 at 10:53 AM
    #134
    ejewels
    CT
    Right, but at that point you already messed with the angles (installing the shims) and might not even have needed them.
  15. Nov 19, 2018 at 11:31 AM
    #135
    TacoSnacks
    TacoSnacks Member
    NJ
    This is true as well, that's where I'm confused. Do both possibly see how it goes. There is no right answer lol...
  16. Nov 19, 2018 at 11:39 AM
    #136
    ejewels
    CT
    I ordered shims from toytec. Guess we'll see in a week or so. Maybe more. Depends on when I can get them installed. If I wait too long I may just say F it and live with it. But today at lunch, I took it out again. Its definitely at 20-25mph and its like minor rumble strips. Similar to aggressive tires. Just seems a tad more pronounced which leads me to believe its not just the tires. Also, didn't Toyota have this same issue on stock trucks then issued a TSB? My stock leafs came with the little shim... so I'm wondering if I try that before the 3 degrees.
  17. Nov 19, 2018 at 11:50 AM
    #137
    ejewels
    CT
    I just ordered them. One question I do have, is once I take out the center pin from the Dakars, and use the new longer one from toytec (and the shim) what do I torque it to? Seems OME would torque that to a specific tightness?
  18. Nov 19, 2018 at 12:37 PM
    #138
    ejewels
    CT
  19. Nov 20, 2018 at 6:00 AM
    #139
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
  20. Nov 20, 2018 at 7:24 AM
    #140
    ejewels
    CT
    I ordered the 3 degree shims. Hoping that will fix things. Will take out my CB drop as well to test. 3 degrees seems to work for most people (I'm hoping).
    What inclinometer did you order? Also, can you take these measurements when the truck is just on the ground?
