FINALLY, MUCH NEEDED VIDEO! P0328 Knock Sensor Wire Harness REPLACED! CHEWED BY MICE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by IcePlant, Jul 7, 2022.
  1. Mar 13, 2025 at 4:44 AM
    eyball
    eyball Well-Known Member
    Dudley, MA
    20 Double cab TRD Sport Voodoo Blue
    Maybe a silly question but should you use loctite on any of the bolts when reassembling? Thanks!
  2. Mar 14, 2025 at 11:21 AM
    denimdan73
    denimdan73 Well-Known Member
    2022 TRD Off Road DCSB
    Pro Skid Plate - Lone Star Knock Off Trail Edition Lift - DIY - Toyota Parts
    Definitely need to replace the O-Rings.
    The dealer didn’t replace them and they failed a week later. Had to take it back for them to do it again over a ten cent O-Ring.
  3. Mar 14, 2025 at 11:29 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Buy one of these or similar place it on the driveway in front of your truck. It’s been working for me for two years.
    https://a.co/d/48pbQQR
  4. Mar 14, 2025 at 3:20 PM
    eyball
    Dudley, MA
    Thanks for the advice. I ordered the orings and washers for the driver side that I took apart. They are like $5 each. I’ll check into that mouse deterrent as well. Was thinking about one of those under hood ones maybe as well.
  5. Mar 14, 2025 at 3:27 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I haven’t seen the under hood ones send me a link if you have one.
    Edit: Never mind I just googled it. Thanks
  6. Mar 24, 2025 at 7:12 AM
    assist
    assist Roadside Assistance
    New Hampshire
    2022 Silver TRD S 4X4
    Just did this repair yesterday, took me 10 hours to do while working alone. The worst part of the entire job is trying to get the old knock sensor wire unclipped from the two points that it attaches to the coolant crossover pipe. I was able to get the left one unclipped from below using my fingers because the wings were pretty easy to push in, but the one on the back center seems impossible due to lack of room and the clip wings being extremely hard to depress. With the new wire secured in every spot except for that one, it seems like it will stay put.
    I replaced the intake manifold gaskets, but did not replace any of the 18 fuel injector rings. The truck started up and is running fine but I'll report back in this thread if any issues arise from reusing the injector rings. Also, when installing the lower fuel rails, I did not have to remove any of the studs, but I did have to use a little WD40 on the largest injector rings to be able to fully seat the rails easier.
  7. Mar 24, 2025 at 3:01 PM
    eyball
    Dudley, MA
    The video was a huge help in fixing my truck. I was able to replace the harness by just removing the driver side lower fuel rail. The hardest part was getting the stupid clips released on the harness. Just like others I broke off the rear one but was able top get back there with a utility nice and cut off the rest. The only other issue was getting the lower fuel rail to seat flush and I think that’s because I used new o-rings. I sprayed a little WD40 on them and took some extra time to make sure the injector clips were in place then started tightening the two nuts on the rail and then its was flush. The rest of the job is easy but it sucks leaning over the engine for so long. Thanks again Vince for the help! Did I mention I hate mice?
