Finally ordered some more stuff for my truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by David10MGM, Jul 9, 2010.
  1. Jul 9, 2010 at 6:35 PM
    David10MGM
    David10MGM [OP] Active Member
    David
    Tennessee
    10 PreRunner TRD Off Road MGM
    Camburg spindles, bilstein 5100's @ 1.75, All-pro 3in leaf, 1.5in block, 5125's
    I ordered my wheels and tires, spindles, and 5125's this week. :D I ordered 17in pro comp 7028's with nitto trail grapplers in 295/70. I also ordered Camburg 4in spindles and 10in travel 5125's for the rear to go along with my 5100's up front. Now I have to decide on which combo to get 4 - 4.5in of lift in the rear. Been thinking about the shackle flip from armor tech with 1.5in shackle and 2in aal. What do you guys think?
  2. Jul 9, 2010 at 6:38 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    I think Kevin from ATO has put a hold on the shackle flips last I saw. Something about tweaking the design IIRC. But if he's making them, that sounds like a pretty good setup for the rear. Only thing you might consider, is entirely new leaf packs, such as OME, Alcan, etc. They're spendy but smoother than factory and offer better off-road flex and ride.
  3. Jul 9, 2010 at 6:43 PM
    bjohnson23
    bjohnson23 Well-Known Member
    Brandon
    Bama(ROLLTIDE)
    07 prerunner trd sport
    where did you order your spindles from?
  4. Jul 9, 2010 at 8:25 PM
    David10MGM
    David
    Tennessee
    I ordered my spindles straight from Camburg and got a 10% discount for mentioning TacomaWorld. Talk to Jeff when you call Camburg.
  5. Jul 10, 2010 at 7:01 AM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    295? Rubb-a-dubb-dubb...
  6. Jul 10, 2010 at 7:07 AM
    oofy15354
    oofy15354 Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
    i want pictures!
  7. Jul 10, 2010 at 10:49 AM
    RelentlessFab
    Eric
    :laugh:..... Maybe a little @ 4" of lift but trimming should fix it... I'm runnin 35's on 3" of lift! :D
  8. Jul 10, 2010 at 11:02 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    I'll be running 35's on 3" of lift soon as well.
  9. Jul 10, 2010 at 11:24 AM
    sp8ed2010
    sp8ed2010 Well-Known Member
    Dale
    Tempe AZ
    2010 prerunner trd or
    Cant wait to see some pics! Those are the same wheels and tires I will run after I get spindles.
  10. Jul 10, 2010 at 11:57 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    He wont rub at 4"
  11. Jul 10, 2010 at 11:58 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    depends on the bs on the wheel he got
  12. Jul 10, 2010 at 11:59 AM
    08pretaco
    Oliver
    az
    camburg says that "largest" you can run is 285's with 4.5 bs but if he got wheels with 4 bs he should be good
  13. Jul 10, 2010 at 4:45 PM
    David10MGM
    David
    Tennessee
    If I have to do some trimming it is ok, I expected that. I will have my 5100's set at .85 so I should have just under 5in in the front. I've got the same backspace as 1Blkt and his fit so I should be fine. I've just got to figure out what I will do to lift the rear around 4 to 4.5 inches.
  14. Jul 10, 2010 at 4:58 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    this is gunna look awesome
  15. Jul 12, 2010 at 4:53 PM
    David10MGM
    David
    Tennessee
    Got my wheels in today!!
  16. Jul 12, 2010 at 4:55 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Ha! Those are the same wheels I am running on my Tundra.
  17. Jul 12, 2010 at 6:01 PM
    DrRabbitFurHead
    Salem, VA
    If he doesn't flex and turn at the same time, may be ok... Otherwise, I had to cut and weld the cab mount running 285's with a 3" lift. It could come down to an offset/backspace and rim width...
  18. Jul 12, 2010 at 6:24 PM
    oofy15354
    Dave
    Massachusetts
    pics? i love my tundras :D
  19. Jul 13, 2010 at 6:22 PM
    David10MGM
    David
    Tennessee
    Got my tires in today!!! Just waiting on my spindles, brake lines, and 5125's. Still gotta order my leaf pack and then time to get all of this stuff on. Hope to have it all done in a couple of weeks.:D
  20. Jul 13, 2010 at 8:24 PM
    beef TACO no rice
    beef TACO no rice Well-Known Member
    Orlando, FL
    07 taco single cab
    hey, how much did you end up spending in total?..
