finally pulling the trigger.. can the experts review before i order
Discussion in 'Suspension' started by mickyd9990, Feb 20, 2011.
  1. Feb 20, 2011 at 4:49 PM
    mickyd9990
    mickyd9990 [OP] Well-Known Member
    marc
    ri
    07 tacoma off road
    Ok so the wheels I want I can not get...
    So I have a grand to put on some lift.. so just trying go get some expert opinions on compatibility and if im forgetting anything.. so this is what im thinking of ordering
    Bilstein 5100 at .85
    Eibach coils
    Lr. Uca
    2 in aal
    Maybe a lean spaced.. opions on that
    I have stock rims and tires for now.. and want the truck looking level. Or slightly raked
    So am I missing anything else.. or is there a better option out there?
  2. Feb 20, 2011 at 4:53 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Looks good. Might as well put the 1/4 spacer on the driver side since you're gonna have the suspension apart.
  3. Feb 20, 2011 at 4:57 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    1.5" aal and 1.75" will put you all most level. Less then 1" of rake.
  4. Feb 20, 2011 at 5:00 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    I am doing the same thing next week. Only difference I am using the 1.5 AAL and the shims, and carriage bearing drop. You should get the shims and just put the shims in. And then if you do have vibes, put the carriage bearing drop in. And you will need the rear 5100's as well. Good luck and post pics.
  5. Feb 20, 2011 at 5:00 PM
    mickyd9990
    marc
    ri
    07 tacoma off road
    Should I get the diff drop or just wait and see if I get the vibes...
    Ya I think ill get the lean spacer.. might as well..
    This setup should give me about 2.45 correct...
    I've read here that some ppl are adding more spacers to bring it to a full three in?? Is that recomended
  6. Feb 20, 2011 at 5:01 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    you might need longer shocks in the back. not 100% sure tho
  7. Feb 20, 2011 at 5:01 PM
    mickyd9990
    marc
    ri
    07 tacoma off road
    Yes I will have the rear 5100 too.. what are the shims for??
