Finally settled on a lift (I think) thoughts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evile, Aug 13, 2014.
  1. Aug 13, 2014 at 9:46 AM
    evile
    evile [OP] Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    So after much research here and else where I think Ive decided on a lift. Ive got a 06 TRD Off Road double cab prerunner with an ARE camper on the back. trucks got 126k miles on it and Ive decided since I wont be getting a new one anytime soon time to spruce it up a bit.
    the extent of my off roading is the beach or a fire road out in the woods no mudding or rock climbing and this is my everyday driver 44miles a day so I want to keep a halfway decent ride. I'm also wanting to keep this under 1K not including tires.
    As for tires I'm going with Cooper Discover AT3 SUV P265/75R16 (these are P rated not the LT AT3)
    I'm prettyu sure this is the lift I want. Its in my price range no diff drop and the front top spacers with the 2" aal
    http://toyteclifts.3dcartstores.com/Bilstein-Adjustable-lift-kit-with-5100-shocks_p_132.html
    but other than the 5100 shocks is there any other benefit to it over this one? with the spacers and 2"aal
    http://toyteclifts.3dcartstores.com/BEST-SELLER-3-Lift-With-front-coils-rear-options_p_233.html
  2. Aug 13, 2014 at 9:51 AM
    smithr1730
    smithr1730 Well-Known Member
    Rob
    Columbus, Ohio
    '15 TX Pro
    Offroad parts and such
    Are you planning on keeping the stock shocks if you go with the second option?
  3. Aug 13, 2014 at 9:53 AM
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    1st one will fit your needs more and is best bang for $
  4. Aug 13, 2014 at 9:55 AM
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    Are you sure thats what you want? think about it.
  5. Aug 13, 2014 at 9:58 AM
    evile
    Orlando, Fl
    Yes
  6. Aug 13, 2014 at 10:00 AM
    evile
    Orlando, Fl
    I want to raise the truck a little call it a mall crawler if you want without spending over a grand is there a better option?
  7. Aug 13, 2014 at 10:03 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    How much lift are you looking to go for? and you do NOT want to keep the stock shocks.... they are horrible and top out real hard with stock suspension... throw in an AAL and its going to be horrible.
    You can definitely save some money if you stick with the stock coils. I run 5100's up front with stock TRD OR coils at 1.75 and the ride is nice, also added a wheelers 2 in single AAL (and OME N182 shocks in the rear) and a 1/4in top plate spacer on the driver side and the ride is the perfect firm.
    Either way 4 5100's, 1/4 top plate spacer, 2in single AAL runs $415 at wheelers off road.
    Now if you plan on doing more lift than yeah the stock coils at 2.5in are going to be stiff and thats where you need new coils... you are also going to have a HARD time getting alignment into spec at 2+ in of lift in the front.
  8. Aug 13, 2014 at 10:15 AM
    evile
    Orlando, Fl
    I was under the impression that you get alignment issues over 3 in. If that's not the case how high can I go without putting ucas in?
    Would the 4 5100s stock coils and aal be better then?
  9. Aug 13, 2014 at 10:17 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    2.5"+ it is recommended you get new UCA's
    New leaf pack >>>>>>>>>>>>>>>>> AAL :thumbsup:
  10. Aug 13, 2014 at 10:17 AM
    nd4spdbh
    SoCal
    You are going to be real close at 2-2.5in of lift at the max adjustment for alignment, and even then you are going to have a caster spec thats not ideal. 3inch, no way you are going to get that aligned properly with stock UCA's.
  11. Aug 13, 2014 at 10:41 AM
    evile
    Orlando, Fl
    So it sounds like the 5100s and the aal are the better option for what I'm looking for. What setting would I use the on the front?
  12. Aug 13, 2014 at 10:50 AM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    I have this lift been almost on for a year now. You'll like it, mine is set up for 3 inches. Im running stock ucas and in spec minus right caster ever so slightly. tires are wearing beautifully. yes it is more difficult to get it in spec with stock ucas at 3 inches but it can be done contrary to what some know it alls on here will say. just find a good shop that is experienced with lifted trucks when you go to get it aligned.
  13. Aug 13, 2014 at 10:51 AM
    ZachMX
    Wrong, mine is all in spec with this lift at 3 inches with stock UCA's. Right caster is a smidge off, everything else in spec. Depends on who you take it to and how much work they are willing to put into getting in spec.
  14. Aug 13, 2014 at 10:56 AM
    tacoman00
    tacoman00 Your Average Joe
    Rockville, MD
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    wait he's a pre runner.. I'm not very bright on lifts and such, but I thought pre runner and 2wd guys can do mantric spindles which are much cheaper?? Atleast thats what I've read....?
  15. Aug 13, 2014 at 10:57 AM
    evile
    Orlando, Fl
    I have access to an alignment machine and Ford certified in suspension and chassis.
  16. Aug 13, 2014 at 10:57 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    mind posting a pic of your alignment sheet?
  17. Aug 13, 2014 at 11:00 AM
    evile
    Orlando, Fl
    What's this about spindles and being cheaper
  18. Aug 13, 2014 at 11:04 AM
    nd4spdbh
    SoCal
    yeah you will get toe and camber in spec, but your caster will be at or below the low end spec which will make the truck feel very wandery down the highway .
    Its not the matter of a shop that knows what they are doing, its the matter that there just is only so much adjustment on the lower control arm to change the camber / caster.
    But hey if you want to top out your upper ball joints and have a truck that wanders down the highway.... go for a 3in lift on stock UCA's
  19. Aug 13, 2014 at 11:45 AM
    evile
    Orlando, Fl
    Yeah I did a quick search on those spindle lifts and defiantly not cheaper.
    OK so if I want to avoid the UCA and alignment issue stay 2inches or under
    5100s all around fronts set at??? and a 2inch aal
  20. Aug 13, 2014 at 11:51 AM
    mAtTyG04
    Edmonton
    2019 Quick Sand OR
    ^:thumbsup:
