find replacement struts
Discussion in '1st Gen. Tacomas (1995-2004)' started by dspratt, Oct 24, 2011.
  1. Oct 24, 2011 at 6:53 PM
    dspratt
    dspratt [OP] New Member
    socal
    1999 tacoma 4x4
    6" trail master lift kit
    I have 1999 Toyota Tacoma 4x4 extra cab with 6" trail master lift. Struts are bad they dont make struts anymore. Any idea what will replace them or wherer to find?
    Dspratt
  2. Oct 24, 2011 at 9:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    A quick search of "trailmaster struts" turned up these:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/136037-ideas-replacing-bad-6-trailmaster-strut.html
    http://www.tacomaworld.com/forum/1st-gen-tacomas/136421-strut-mounts.html
    http://www.tacomaworld.com/forum/1st-gen-tacomas/135803-6-dicontinued-trailmaster-lift-help.html
    Looks like a lot of good info here.
  3. Dec 11, 2011 at 7:06 PM
    StaticFilter
    StaticFilter Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
