Finding a rear axle build
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheOnlyRedOne, Aug 2, 2018.
  1. Aug 2, 2018 at 6:50 PM
    TheOnlyRedOne
    TheOnlyRedOne [OP] Member
    Sean
    2005 red tacoma sr5
    None yet
    So I’d like to get some advice I’m looking at saving up for a rear axle for my tacoma it is a 4X4 and Id like to put an axle on it that will outlast the truck and also allow me to do anything I won’t to with it as well.... any ideas?
  2. Aug 2, 2018 at 7:02 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  3. Aug 2, 2018 at 7:07 PM
    TheOnlyRedOne
    Sean
    2005 red tacoma sr5
    None yet
  4. Aug 2, 2018 at 7:09 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @jberry813
    jberry813 likes this.
  5. Aug 2, 2018 at 7:25 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Whatever you decide to buy
  6. Aug 2, 2018 at 7:56 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  7. Aug 2, 2018 at 8:01 PM
    TheOnlyRedOne
    Sean
    2005 red tacoma sr5
    None yet
  8. Aug 2, 2018 at 8:03 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    A lot.
    And a lot.
    Beef Nachos likes this.
  9. Aug 2, 2018 at 8:05 PM
    TheOnlyRedOne
    Sean
    2005 red tacoma sr5
    None yet
    Fair enough I think of a lot as like 8 grand and time was a lot as two-three weeks
  10. Aug 2, 2018 at 8:10 PM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    Curious, what shortcomings are you experiencing with your current axle?
  11. Aug 2, 2018 at 8:13 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I was thinking about going with a custom diamond axle for my rear. 9.5" center with full float hubs and disk brakes. But I think it'll be cheaper for me to find tons for the front and rear and sell my front diamond axle.
  12. Aug 3, 2018 at 4:52 AM
    TheOnlyRedOne
    Sean
    2005 red tacoma sr5
    None yet
    I’m not having any short shortcomings but I know what I want for my truck as a future and hope to get it to I just need to see how to save and prepare for that
  13. Aug 3, 2018 at 7:25 AM
    Toyoland66
    Colorado
    09 GX470
    Mostly stock on 35s
    Unless you plan to go big: big tires, SAS, or long travel, big horsepower, etc. your money will be better utilized on a number of things before you need to upgrade your rear axle.
    Recommending something will vary depending on your ultimate goal for the truck and what you intend to do with it. There are Toyota options, one tons, hybrid axles, and bigger (Rockwell’s, axletechs) depending on your desired outcome.
    Can you clarify what you intend to do?
  14. Aug 3, 2018 at 7:28 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    A friend is doing a corporate 14 bolt currently. He's probably gonna have $2k in it, all his time (a few months of weekends), and maybe a detroit locker or something. That's cheap, and doesn't even include the best options for lockers, and that's junkyard digging too to keep costs down.
    I can't see it happening for less than $4k or $5k new parts. If you're paying someone, probably more.
    Also consider new u-joints, possible different drive shaft, re-gears (or gear selection), fluids, upgrade axle shafts? (why not!!), upgrade brakes on new axle (hey, might as well go disc, right!?!)...so before someone says "I can do it for $200 in a garage in a weekend." It sounds like this guy can't. And neither can I. Just sharing what I learned the hard way.
  15. Aug 3, 2018 at 8:23 AM
    Slamuel
    Slamuel Well-Known Member
    Sam
    Tacoma
    I might be wrong since I don’t off-road my taco but...
    Can we not get CrMo axles and stuff like most others? If I were GONNA wheel this is truss the top and get some high strength shafts and other parts with a higher yield.
    Might be more expensive though hahaha
  16. Aug 3, 2018 at 8:31 AM
    Toyoland66
    Colorado
    09 GX470
    Mostly stock on 35s
    Ring and pinion typically go before the shafts
  17. Aug 3, 2018 at 1:33 PM
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    I've personally seen this happen 3 times. I will agree with this.
  18. Aug 5, 2018 at 8:17 AM
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    I'm starting to work on this now. I have a late model disc braked 14 bolt. I believe its only about 2" wider than the factory diff, so I'm not gonna mess with that. Plan is to have the hubs redilled to 6x5.5. If I can find a factory rotor that will work, that would be great, otherwise I'll drill the rotors too.
    I have an ARB for it on a shelf and mine already has 4.88s. I'll have to have ebrake cables modded to work. Hopefully the MC will move enough volume for the brakes. Otherwise that'll have to go as well. I'm sure Ill lose my ABS, but dont really care on that. I have a driveshaft that should work as well.
    I'm robbing most these parts off my SAS project. I'm gonna take it in a new direction in a few years when I have a larger budget. I picked up a set of Axletech 4000 MRAP axles for it.
