Finding my Taco Cold!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CanTac, Dec 23, 2008.
  1. Dec 23, 2008 at 4:56 AM
    CanTac
    CanTac [OP] Well-Known Member
    Peterborough On./Ocala Fl.
    09 TRD Sport 4X4 D/Cab Long Box
    In this cold weather... 0 and below, the 09 Taco doesn`t seem to warm up too well. Anybody else with the same problem. Seems like the thermostat is opening too soon or something!
    Any help would be greatly appreciated.
    Cantac
    Hal
  2. Dec 23, 2008 at 5:53 AM
    BioMed80
    BioMed80 Well-Known Member
    Colorado Springs, CO
    09 Regular Cab
    3" ReadyLift Kit, 31x10.5x15 General Grabber AT2s, AFE Drop-In, Bull Bar, Hella 500FF, Secondary Filter Removed
    Hmm, not sure exactly what you're referring to. Do you mean it takes too long for the coolant temp to warm up? How long is it taking? In any case, my 09 seems to warm up fine.
  3. Dec 23, 2008 at 6:02 AM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    start movin n it will waem up quicker....... mine wuld take FOREVER to get to a good temp just sittin there
  4. Dec 23, 2008 at 6:07 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    It was 5 degrees here in WV yesterday morning, it took a good fifteen minutes for mine to reach the middle temperature range while sitting and idling. Drive it and it will warm up quicker.
  5. Dec 23, 2008 at 6:08 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    Yeah, you will have to get it moving to see the oil temps go anywhere. I started mine up yesterday after work, let it run for about 5 min, and gauges did nothing. I went about a 1/4 mile down the road and they were normal. When I start mine, I listen to to the engine. It will drop down to the idle rev after a little bit.
  6. Dec 23, 2008 at 7:59 AM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    If it is below 0 alot you should get a oil plug heater and plug it in over night. All our cars in Alaska had to have them. If you don't know what those are the are a plug that replaces your drain pan oil plug. It has a big old heating element on it. It's totaly safe, they have been out for decades. You plug it in and it keeps your oil warm through the night. Your truck will not have half as much to warm up in the morning.:D
  7. Dec 23, 2008 at 8:04 AM
    Bearskill
    Sac
    I thought you would not get a temp reading untill the thermostat opens? I thought that was the whole point. It's a closed system till the thermostat opens, then it starts to warm the whole system. Oh, I just read your thread again. Ya, Maybe. I new one should only be 30 bones or so. I don't really see how it could go bad though.
  8. Dec 23, 2008 at 8:33 AM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    right now it is in the single digits outside and I let my truck sit there for about 5 minutes while I have a smoke, when I get in the temp gauge has not moved. But within a block or two it is moving up rapidly, it just takes a little longer this time of year thas all.
  9. Dec 23, 2008 at 8:50 AM
    OLEFART
    OLEFART Active Member
    northern illinois
    09 base
    integrated sirius, tonnaue cover
    mine warms up good, - 29 wind chill, warms up in 5 min or so
  10. Dec 23, 2008 at 9:05 AM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    My 09 seems to warm up just fine. The coldest I have been in so far is about 10 windchill but no problems warming up. I watch the temp on my scan gauge II and once it gets close to 100 it warms up pretty quick from there
  11. Dec 25, 2008 at 9:07 AM
    JonO81
    JonO81 Member
    Central Wisconsin!
    09' Tacoma 2.7,4x4,5-speed
    Sound system, UWS high-pro.tool box, Aries bullguard/skidplate, upgraded to17'Tacoma sport rims.
    its been -20 -30 below windchill here in Wisconsin for past week or so and mine seems to warm up just fine!! you got remember that cold is a vehicles worst enemy well one of them,, but anyhting below zero is COLD.. and its gonna take a while to warm things up to driving temps for your engine. I usually will let mine warm up for a good 10-15 mins before I drive it!
  12. Dec 25, 2008 at 10:45 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Aren't you backwards? Shouldn't you be in Florida? I know all the snowbirds are heading down here (Myrtle Beach) now.
  13. Dec 26, 2008 at 1:44 PM
    sch0enne
    sch0enne Well-Known Member
    penticton British Columbia Canada
    03 Tacoma TRD
    bed lights, cobra 19 dx cb radio, flow pro muffler
    yeah mine seems to do fine. Im working in northern saskatchewan right now and its
    -45 without windchill. i make sure to plug mine in when im not driving and im good to go. I do notice in that cold that my clutch tends to stay stiff even after fdriving it for an hour or so
  14. Dec 26, 2008 at 2:39 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Warming up fine here as well. Its been staying around 10-20 degrees when I go to work in the morning. Except yesterday when I was getting off shift, it took about 4 seconds for my trucks engine to turn over and start. It was probably about 25 degrees out. This was probably the 2nd time this has happened within the last 2 1/2 years so I ain't worried about it!
