Finished CB Installation
Discussion in 'Audio & Video' started by ahigginsdeca, Apr 2, 2008.
  1. Apr 2, 2008 at 8:04 PM
    ahigginsdeca
    ahigginsdeca [OP] Higgins
    Alex
    Fort Collins, CO
    08 TRD shortbed
    3" Revtek Suspension Lift with a rear aal, 285/70/17 Pro Comp Xtreme M/T & Pro Comp Extreme Alloy 7189 wheels, magna flow exhaust, CB with dual antennas, AFE Cold Air Intake, CB Radio with dual antennas and a bull horn
  2. Apr 2, 2008 at 8:13 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    ditto...i'm having probs getting mine under 3.5:1. i've been talking w/ kilo and i'm gonna try some different things when the weather clears up
  3. Apr 2, 2008 at 8:17 PM
    ahigginsdeca
    Alex
    Fort Collins, CO
    08 TRD shortbed
    for a while, I couldn't figure out why I wasn't getting any reception and the SWR was so high, but then I figured that my cell phone charger, which plugged in right next to my CB, would really screw it all up. As soon as I took it out, everything went to wear it's supposed to be and I so far, I've gotten reception up to a little over 3 miles...
    The next step is to intall a PA system with the CB...:)
  4. Apr 2, 2008 at 8:31 PM
    The_Hodge
    SC
    hmm...might need to unplug my radar detector and see how it is. i wanna get me a lil cheap speaker off ebay and hook it up to my PA as well
  5. Apr 2, 2008 at 8:35 PM
    ahigginsdeca
    Alex
    Fort Collins, CO
    08 TRD shortbed
    Yeah, the charger was definately the problem. I'm not quite sure what I need, specifically, for the PA so you should let me know if you find out...
  6. Apr 2, 2008 at 8:44 PM
    The_Hodge
    SC
    u should have a PA jack on the back of the cb...and if so, all u have to do is buy a horn/speaker for it. i actually just ordered one off ebay. here's what i got.....
    http://cgi.ebay.com/BLACK-PA-SPEAKER-for-CB-or-HAM-RADIO-Extra-Loud-NEW_W0QQitemZ360038934192QQihZ023QQcategoryZ48695QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
  7. Apr 2, 2008 at 8:49 PM
    ahigginsdeca
    Alex
    Fort Collins, CO
    08 TRD shortbed
    do you know where I can get a waterproof one? That one that jhodge83 posted a link to seemed like what I need. Just the speaker and 10' wire...
  8. Apr 2, 2008 at 8:53 PM
    The_Hodge
    SC
    the one i posted is weatherproof and for marine use as well....factory warranty and 2 year replacement warranty from the seller....and they say u can hear it from 1-2 blocks...we'll have to see about all that.
  9. Apr 2, 2008 at 8:55 PM
    ahigginsdeca
    Alex
    Fort Collins, CO
    08 TRD shortbed
    I'm probably going to buy one. It wasn't that expensive either, but I may get what I pay for. It would be worth it to at least try though. You'll have to tell me how it does.
  10. Apr 2, 2008 at 10:32 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    3.5:eek: Holy cow, dude!
    And you haven't fried you radio?
    I'd almost check for a short. Either in the wire itself
    or the antenna mounting bracket.
  11. Apr 3, 2008 at 8:39 AM
    ahigginsdeca
    Alex
    Fort Collins, CO
    08 TRD shortbed
    Everything is working fine and I mounted dual antennas, which don't really help with distance being that they are only about four feet apart, and a really high quality CB. That 3.5 (approx) was from a truck straight in front of me on a flat and straight highway. For what mounted, it seemed normal. Am I completely wrong or is it fine?
  12. Apr 3, 2008 at 8:43 AM
    ahigginsdeca
    Alex
    Fort Collins, CO
    08 TRD shortbed
    "CB operators can expect a fairly consistent operational range of three to five miles in an area of limited obstructions."
    From Firestik Antenna's Website
    From that, I'm hoping that everything is in proper working condition, but only time will tell...
  13. Apr 3, 2008 at 9:26 AM
    CtryBoyInMT
    I think your setup will work well, Just make sure to tune your SWR to an acceptable level. Otherwise your radio needs to work so hard to push 4 Watts out the antenna it will eventually die.
    The Cobra 29's or any Cobra is a good radio. And Firestik is the most popular antenna out there.
    Good Choices.
  14. Apr 3, 2008 at 9:28 AM
    ahigginsdeca
    Alex
    Fort Collins, CO
    08 TRD shortbed
  15. Apr 9, 2008 at 7:41 PM
    slaptheebass
    slaptheebass Member
    01 Tacoma TRD
    I installed and tuned my cobra compact and at the max ive talked to my buddies at 12 miles, antenna and tuneing are the keys
  16. Apr 9, 2008 at 9:24 PM
    ahigginsdeca
    Alex
    Fort Collins, CO
    08 TRD shortbed
    oh wow! I've never even heard of that, but I guess it's possible... What antennas do you have?
  17. Apr 10, 2008 at 5:23 AM
    ANDYTACOMA
    ANDYTACOMA NOMAD
    2006 access cab trd offroad 4x4 black sand pe
    fog light mod /parking light mod /after market stereo /bed lights/yeasu ft8700/uniden bct15
    Just remember mounting "Dual" antennas do NOT help with radio frequency transmission distance. and if the antennas aren't mount a certain distance apart(distance is affected by the electrical length of the antenna )they could in fact have adverse effects on the radiation pattern of the antenna also this setup up is very directional (causing unwanted signal reflection from the vehicle body). The best thing i could recommend using (for the greatest transmit and receive distance) is a single stainless steel 102" (or cut to length for the exact frequency) dipole antenna mounted on a good ground plan mounted as hi as possible effectively creating a "balanced" radiation pattern for the RF energy to disperse upon
    sorry about the rant but I'm a Ham radio geek and I just couldn't help myself!
  18. Apr 10, 2008 at 6:09 AM
    slaptheebass
    slaptheebass Member
    01 Tacoma TRD
    I got just a 5 foot fiberglass K40, and one night i was talking to my buddie on his base station at exactly 11.8 miles.
  19. Apr 10, 2008 at 6:53 AM
    ahigginsdeca
    Alex
    Fort Collins, CO
    08 TRD shortbed
    That's really good distance. I put on dual 3' antennas and am thinking to replace them with 4' antennas, but I don't know if that will make that much of a difference
  20. Apr 10, 2008 at 7:11 AM
    ANDYTACOMA
    ANDYTACOMA NOMAD
    :rolleyes::rolleyes: Yeah more antennas is definitely the answer why stop at two maybe you should get 4.. or 6 ya thats it six antennas that will do the trick!:D and then ........:rolleyes::rolleyes:
