Finished Interior painting/sound deadening!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XPOTRPR, Mar 12, 2012.
  1. Aug 5, 2012 at 6:46 AM
    #41
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    this thread is the $h!t. Matching these little pieces really tie the interior together (like a good rug). I am so doing this.
    + for the OP for being brave and tearing the interior apart with lighters and razors.
  2. Aug 5, 2012 at 7:12 AM
    #42
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks man. I appreciate that. :)
  3. Aug 5, 2012 at 11:55 AM
    #43
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Finished it up this morning. I'm pretty happy with the results. Thanks for the help and all the info
  4. Aug 5, 2012 at 1:49 PM
    #44
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Turned out great man! nice work. :thumbsup:
  5. Aug 5, 2012 at 3:28 PM
    #45
    TennesseeFan76
    TennesseeFan76 I intend to live forever. So far, so good.
    Phill Goodfactor
    Georgia
    2005 PreRunner DCLB
    3 inch lift, Debadged, 5% Tint, Custom Stereo, BHLM, Fog Light Mod, Sockmonkey Decals, OEM Bedmat, Plasti Dip Front Valence, Slims 6K HIDs (thanks goes to TheGloryFades), Hyper yellow fog lights, LED interior lights, Satoshi Grille with FJ Emblem, Pro Comp lights behind Satoshi, FatMat
    Dude! Looks real good!!
  6. Aug 5, 2012 at 4:31 PM
    #46
    Fiend13
    Chad
    So you didn't heat the horn emblem up at all? just flat tip and razor? bet it was noisy, lol
  7. Aug 5, 2012 at 4:43 PM
    #47
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Lol. Nah, wasn't that bad.
  8. Aug 5, 2012 at 4:48 PM
    #48
    Larry
    Larry CARL
    CARL
    what? you have no access to cardboard or old newspaper?
    I know it's only a concrete curb...but one should show a little respect for others property.
    btw, your workmanship is very nice. :cheers:
  9. Aug 5, 2012 at 4:50 PM
    #49
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Should have put some down, but its hardly noticeable on the curb, plus there are construction markings everywhere. Lol
  10. Aug 10, 2012 at 8:30 AM
    #50
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
  11. Aug 10, 2012 at 8:38 AM
    #51
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    just to whore my stuff here is what i did, i used carbon fiber wrap, been there for about 2 years now no problem
    RIDER34 likes this.
  12. Aug 21, 2012 at 1:36 PM
    #52
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Your white interior accents look awesome...very tastefully done! Great job!! :)
  13. Aug 21, 2012 at 2:23 PM
    #53
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks dude! I appreciate that. :cheers:
  14. Sep 3, 2012 at 6:20 PM
    #54
    calixto25
    calixto25 Well-Known Member
    Arizona
    TRD sport
    Hids, billet grille, headlights, fog lights, k&n intake, throttle body spacer, led taillights, led bulb conversion.
    How did you take off the ring around the shifter and the one on the shift knob?
  15. Sep 3, 2012 at 6:48 PM
    #55
    Fiend13
    Chad
    The ring around the shift knob just pulls right off the knob, and the ring around the shifter, just use a lighter on the back side for a few seconds at a time in different areas and you should be able to pry it off. It took me a few minutes to get it off. Start reading from post #34, that's where I started asking questions about that piece.
  16. Sep 3, 2012 at 6:52 PM
    #56
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    truck looks great. nice and clean! especially with no emblems/decals outside. how did you get the emblem off the steering wheel... then back on the steering wheel?
  17. Sep 3, 2012 at 8:59 PM
    #57
    calixto25
    Arizona
    TRD sport
    Did you guys sand the plastic pieces before you painted it? If so what grit did you use? I am painting the pieces now and the paint has little bubbles all through out the paint.
  18. Sep 3, 2012 at 9:08 PM
    #58
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Any more details of the steering wheel? I want to try it. Would a heat gun and a small flat head work?
  19. Sep 3, 2012 at 10:02 PM
    #59
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    If you guys go through the posts, I think its the 2nd page.. I wrote up what to do. Its in my build as well.
  20. Sep 5, 2012 at 8:33 PM
    #60
    Drunknsloth
    Retribution
    South West
    I just wanted to clarify. I didn't want to break any unexpected tabs or anything :D
