Finished Interior painting/sound deadening!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XPOTRPR, Mar 12, 2012.
  1. Sep 8, 2012 at 11:02 PM
    #81
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Thank you! Any recommendations on best way to get it back on?
  2. Sep 8, 2012 at 11:06 PM
    #82
    TacoDaddy
    TacoDaddy Just call me Daddy
    Brian
    Costa Mesa, CA
    '11 Sport
    So's your front bumper but who's complaining?
  3. Sep 8, 2012 at 11:07 PM
    #83
    TacoDaddy
    Brian
    Costa Mesa, CA
    '11 Sport
    2 part epoxy and use masking tape to hold it on till the epoxy cures
  4. Sep 9, 2012 at 8:13 AM
    #84
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Hmm I'm guessing you don't know me and OP are friends and I have a black and white interior as well lol
  5. Sep 9, 2012 at 9:45 AM
    #85
    TacoDaddy
    Brian
    Costa Mesa, CA
    '11 Sport
    Whoops! :bowdown:
  6. Sep 9, 2012 at 9:54 AM
    #86
    PLC721
    Patrick
    Chandler, Az
  7. Sep 9, 2012 at 8:41 PM
    #87
    Aw9d
    Aw9d That one guy
    Ha! When I first read this I was like "What the fuck Patrick!"
  8. Apr 12, 2013 at 12:32 AM
    #88
    Kuhl29
    Kuhl29 King of the Goobers
    Brea, CA
    White 07 PrerRunner
    Swayaway stock replacement coils, Bilstein 5100's (rear), Removed Swaybar, Magnaflow Exhaust, 8000k HID Kit, camburg UCAs, camburg spindles, Doug thorley shorties
    LOVE what you did with the custom paint. been thinking about doing something like this for a while, but i have shakey hands, and that makes me nervous when messing with clips..... makes me wanna road trip it and pay you to do it.:p maybe if i can calm these hands down, i'll try it for myself... did you special order the oem black trim paint?
  9. Apr 12, 2013 at 7:11 AM
    #89
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks man! Lol. Honestly, its not too bad. Patience is all. The oem trim paint can be picked up at any local automotive store. Comes in a green can. Called OEM Trim Paint.
  10. Apr 13, 2013 at 12:28 AM
    #90
    Kuhl29
    Brea, CA
    White 07 PrerRunner
    sweet deal, gracias compa!! ill put up some pics within the next 10 days when i have it done....
    one question, alot of people are talking about "baking" the rings and such, what the heck does that mean? literally baking them?!?!?!?!?!?! that sounds like a gamble...
  11. Apr 13, 2013 at 10:41 AM
    #91
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    The tweeter rings? If thats what your referring to then they are talking about the little plastic clips on the backside. They are held in place by tabs that have been heated/melted and lock them in. Just a lighter and some patience and your good to go. Keep the flame off the plastic and just heat them up. Use a small flat head screwdriver to push and pop then out. After paint.. reinstall doing the reverse process. Pop in. Heat.
    Its talked about in this thread somewhere. If you haven't read through it all, take some time and get all the info. Good luck. :thumbsup:
  12. Apr 15, 2013 at 12:08 PM
    #92
    Kuhl29
    Brea, CA
    White 07 PrerRunner
    2 questions: do you need to disconnect the battery to remove cluster panel? and, how does one remove shifter trim, to paint?
  13. Apr 15, 2013 at 12:14 PM
    #93
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    how'd you paint the steering wheel "T"?
  14. Apr 15, 2013 at 12:42 PM
    #94
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I dont think I did. No need. Might be good just in case tho. Are you talking about the thin chrome trim or the entire silver shifter cover?
    Ive posted how to do it several times in here.. just use a small flat head and a small razor blade with alot of patience. Pull up on emblem carefully and cut through the soft plastic tabs underneath to cut it away from the steering wheel.
  15. Apr 15, 2013 at 1:08 PM
    #95
    Kuhl29
    Brea, CA
    White 07 PrerRunner
    The entire silver cover. It looks like the chrome accent on the shifter housing comes off from the back side. But I need to get the cover off to paint it and then I'll pull off the accent piece.
  16. Apr 15, 2013 at 1:22 PM
    #96
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Unscrew the shifter knob... then grab the entire shifter surround by the cup holder and outside of the surround.. firmly pull up. You wont break it. Its snapped into place.
  17. Apr 15, 2013 at 1:31 PM
    #97
    Kuhl29
    Brea, CA
    White 07 PrerRunner
    Moose, you are the king of cool. And I know what's cool, it's my last name. Thank you, sir!!!!!!
  18. Apr 15, 2013 at 1:35 PM
    #98
    PLC721
    Patrick
    Chandler, Az
    You clearly havent met him in person.
    :p JK!! <3
  19. Apr 15, 2013 at 1:36 PM
    #99
    Kuhl29
    Brea, CA
    White 07 PrerRunner
    Hahaha. Your friends are stone cold, buddy.
  20. Apr 15, 2013 at 1:36 PM
    #100
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    No problem. Thanks sir. :cheers:
    And you....
    :wave:
