Fire Extinguisher...get one!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by novataco, Aug 18, 2012.
  1. Aug 19, 2012 at 7:28 PM
    #61
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    See my link above your post. It's about the smallest extinguisher I could find. It's also USA made.
  2. Aug 19, 2012 at 8:25 PM
    #62
    acdronin
    acdronin Well-Known Member
    The 10 is a lot and I thought about what size to get for some time before I purchased the first alert, I wanted a re-chargable and one big enough to knock down a fairly good sized fire or knock it down long enough to pull someone to safety if need be. If the 10 can't do that, it's way too big of a fire to tango with in the first place. I also purchased the 10 for the possibility of being somewhere where additional help is way too far away. I have two additional mounts that I ordered for 5's which will be mounted one more in the bed and one more behind the driver's seat. I also ordered a "Fire Extinguisher Inside" sticker to put on the back shell window. The 10 is secured with a nut that is welded into a spark plug socket with a bolt welded on top that turns it into a giant wing nut. i can crank it down securely but still get it of in about 3-4 seconds. It sounds like overkill until you run into a situation where you would be glad you had them. I drive A LOT of miles and see all kinds of crazy stuff.
  3. Aug 19, 2012 at 9:14 PM
    #63
    afcivmedic
    afcivmedic Well-Known Member
    Tim
    Tehachapi, Ca
    '05 DCSB TRD Sport 4x4
    ICON CO W RESI, ICON RES 2.0 Rear ICON UCA Snug Top Rebel Borla Cat Back DAKAR Leafs Timbren Bumpstops Distinct Offroad Sliders Black HL LED Tailights ARB Bumper with Warn Winch CBI Rear Bumper Tech Deck MaxTrax Lights by @caliraisedled
  4. Aug 19, 2012 at 9:59 PM
    #64
    BBYE V8
    BBYE V8 Please keep TW beautiful: search & stay on topic
    Brian
    StL, MO
    07 AC 4x4 2.7 5sp SR5
    With an '06 AC you've got the bench style jump seats. If you keep them in the flipped forward position, you've got a nice size space between the seat legs and the back of your driver seat on the floor. I've got a 10A 40BC behind mine, fits great, and enough leg room for average size guy.
    FYI: Fire extinguishers can be bought pretty cheap at Costco.
  5. Aug 19, 2012 at 10:47 PM
    #65
    Checkvalve
    Checkvalve Well-Known Member
    San Diego CA
    2013 DCLB Spruce
    Okay, you all have a good start and I'm glad people like you are on the road. However, there is more to fire safety than just carrying some extinguishers around. First, I'll address the "interior suppression systems". CO2 works by displacing oxygen. Halon works by displacing oxygen. As someone else said, chemical extinguishers such as PKP are highly toxic. You DO NOT want free release of these agents inside your vehicle while you are in it. This will only lead to further problems with escape and possibly death from asphyxiation. Next, extinguishers in the cab. They MUST be attached by a bracket with lock pin or other device. When your truck rolls over, that is a pressurized grenade, ready to explode and send itself into your head, missile style, not to mention shrapnel. Finally, the emergency hammers. Get one on each side of your vehicle, permanently mounted to the side carpet near the dash. You must not depend on someone else finding you and extracting you from an accident; these hammers are not perfect, but they will cut your seat belt, and they should be able to break some glass.
    Not trying to step on anyone's toes, but after being in the military for over a decade, I've seen it all, and too many well intentioned people end up hurting themselves and others because they don't have the proper equipment or don't know the best way to store and use it.
    Just remember, in an accident, the number one priority is getting the human life out safely. The car can burn, and stay in the trees, and stay upside down, and so on. The earlier comment about using a high lift for extraction was a good one; use what you have and keep your wits, because for every person who is calm, there are five who are panicking and will provide little help.
  6. Aug 19, 2012 at 10:50 PM
    #66
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  7. Aug 20, 2012 at 12:30 AM
    #67
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    Reading the thread, I couldnt believe this hadn't been mentioned.
    I keep one mounted in my centerconsole. It can cut the seat belt and break the window. To make it even more useful, mine reads tire pressure and is an LED flash light.
    It is a great thing to have. I am thinking about mounting a fire extinguisher in the bed of the truck now.
  8. Aug 31, 2012 at 5:44 AM
    #68
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    A couple of questions for anyone who may know. I have an older fire extinguisher that has been on my boat, I have no reason to believe anything is wrong with it other than the label is faded from the sun. However I did get a new one just because I wanted to and I do grill on my boat. Again I have no reason to believe anything is wrong with it and I don't want to just trash it, so here are my questions.
    1. I sort of answered this is my own response of it being stored on my boat, but I noticed some of you have yours stored outside, do you have to worry about weathering at all and it going bad because of the elements?
    2. This plays off the first question, of the elements that they hold up to, is the Texas heat too much for it to be stored outside?
    3. ...and this goes with ?2, would it be okay to store in my tool box in the bed in the Texas heat? Essentially putting it in an oven during the dead of summer.
    I know it is a "fire" extinguisher so it is probably pretty tolerant to heat, however they are probably not meant to be thrown into a fire (which I know is much hotter than my tool box). I don't want to come out one day and find my tools, straps, and everything else covered in foam.
    Thanks for the help.
  9. Aug 31, 2012 at 6:22 AM
    #69
    K3tsurui
    K3tsurui Well-Known Member
    Ricky
    Upstate NY
    Approved extinguishers are very robust and will unlikely "explode". They contain fire retardant chemicals that are potentially poisonous and occasionally leak. Therefore, you should store it properly. Standing upright in in an approved, enclosed housing/container, out of direct sunlight/heat are ideal. They should also be inspected routinely by approved extinguisher servicing companies. They usually charge like $10 per extinguisher and the process takes less than 5 mins. Most of them will come to your door and do it.
  10. Aug 31, 2012 at 7:01 AM
    #70
    Ragin Devildoc
    Ragin Devildoc MOLON LABE
    Doc
    Grunt Life
    12 Prerunner DCSB SR5
    16x8.5 level 8 guardian w/ hankook dynapro atm rf10, aFe pro dry s, flowmaster dbx exhaust, debadged, 2nd air filter removal
    You are correct on the halon based quote. As a Corpsman I have actually witnessed the death of a sailor on ship who wasn't accounted for having a rebreather during a halon exercise. In open air environments halon is pefrectly fine to use but is quickly displaced by the air around it. Thus why halon works so well in closed spaces. My opinion is don't even waste your time with it.
    A couple of options for rescue tools:
    ResQMe http://www.amazon.com/ResQMe-Escape-Tool-Made-Yellow/dp/B000IDUW5C/ref=pd_bxgy_auto_img_y
    Seatbelt cutter/hammer http://www.amazon.com/Seatbelt-Cutter-Breaker-Escape-Tool/dp/B004TRKBOK/ref=pd_bxgy_auto_img_y
  11. Aug 31, 2012 at 7:34 AM
    #71
    jjew18
    Alliance Airport
    05 PreRunner SR5
    You two seem very knowledgeable in extinguishers, any advice for below VVVVVV
  12. Aug 31, 2012 at 8:11 AM
    #72
    Ragin Devildoc
    Doc
    Grunt Life
    weather does play into the storing of the tank externally if the major components of it are made of plastic or rubber. Temp flux would cause expand/contract of the plastic and elements would cause rubber to crack over time.
    I would say yes on the heat, but more to a person grabbing a hot bottle and burning their hands to use it.
    Personally I would not do that. I would ask the extinguisher guy "precoma" about that.
    Goes along with the answer to your first questions. The quality of the tank and materials it is made out of.
  13. Aug 31, 2012 at 8:30 AM
    #73
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Thank you sir! I may take it to one of the inspectors and see what they say (I didn't know there was such a thing).
  14. Aug 31, 2012 at 3:34 PM
    #74
    Ragin Devildoc
    Doc
    Grunt Life
    Check with your local fire department. They should have a fire marshal or someone that can go over all of this with you also!
  15. Jan 28, 2014 at 2:54 PM
    #75
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Just got 4 Cold Fire sprays for my kitchen, truck, car, and girl friend's truck. It fits nicely in the drivers side door storage compartment:
  16. Jan 28, 2014 at 3:57 PM
    #76
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    I mounted a smallish one in my 06 AC. Might not help if shit gets crazy but it is a hell of a lot better than nothing. It's an ABC type to handle wood, liquid, and electrical fires. I wanted it easy to access and easy for people other than me to find if needed while out of the elements.
    Actually had to use it the other week. Was driving down the road and saw a car that had been hit facing the wrong way. Took a good look and was all holy shit there are flames under that thing!
    I like to roll prepared... recovery gear, pretty extensive first aid kit, CPR mask, various tools, spare serp belt/other various parts, and of course the fire extinguisher. People seem to think I am a good person to road trip with :)
  17. Jan 28, 2014 at 4:13 PM
    #77
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    This thread has inspired me to eventually pick up a fire extinguisher for my truck. Any precautions to take when storing one in the cold? It's gotten to -40(f) already here this winter, wouldn't want anything to blow up in my truck.
  18. Jan 28, 2014 at 4:18 PM
    #78
    chipnoreo
    Anna
    Alaska
    Ram Eco Diesel
    Mine has been down to about -20F and no problems. There should be a safe storage temp printed on the extinguisher somewhere. It is usually a pretty big extreme range.
  19. Jan 28, 2014 at 4:25 PM
    #79
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    All fire extinguishers have to go thru extreme testing to get a UL approval to be sold in the states. One of the tests is the fire extinguisher being put into a freezer for 6 months at -30 degrees and also in a over at 130 degrees for 6 months and after the 6 months the extinguisher is removed from the freezer/oven and has to be able to fire off 95% of the powder in the unit.
  20. Jan 28, 2014 at 5:48 PM
    #80
    medic2230
    Murph
    Bama! Roll Tide
    Halon isn't very human friendly in an enclosed place!!!
