Fire Extinguisher...get one!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by novataco, Aug 18, 2012.
  1. Jan 28, 2014 at 6:17 PM
    #81
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Last summer I got a 5LB Extinguisher. I hope that I never have to use it but it's there just in case I or someone else needs it. I just hope that if you have one that you know how to use it properly. Having First Aid isn't a bad idea either.
  2. Jan 28, 2014 at 8:05 PM
    #82
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    Mine is mounted in my shell
  3. Jan 28, 2014 at 9:00 PM
    #83
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Halon displaces O2 in enclosed spaces and the people die anyway.
  4. Jan 28, 2014 at 9:05 PM
    #84
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I'm starting a group buy on fire extinguishers in response to this thread
    DrFunker likes this.
  5. Jan 28, 2014 at 9:20 PM
    #85
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Cold Fire!
  6. Jan 29, 2014 at 5:29 AM
    #86
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    I am also amazed that people don't carry a pocket knife to cut seat belts with it they won't move. Fire extinguisher to put out the fire plus a pocket knife so you cut a belt and get someone out of a car.
  7. Jan 29, 2014 at 8:30 AM
    #87
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Good Post OP...and good on you and the other folks for helping a
    person out.
    Halon 1301 is ok for enclosed spaces and humans.
    It was designed for occupied computer rooms/data centers etc...
    because it does not leave much residue and is safe for electronics.
    Standard water sprinklers are not going to work so well around electronics.
    The other Halon types and CO2 are not recommended
    as they are not human friendly in enclosed spaces.
    In most outdoor/automotive applications a standard ABC type Dry Chemical extinguisher works best.
    It does leave a mess when activated, but it's basically baking soda,
    so other than some mild eye/throat irritation
    the MSDS on it is quite tame and can be rinsed away with water.
    A 5 lb extinguisher will put out smaller fires, but a 10 lb or larger is better
    for most types of fires...Automotive fires can be hard to put out
    especially if rubber or other materials/fluids have ignited.
    A company called Amerex, in Trussville Alabama makes the best ABC type extinguishers.
    The Kidde types are not that great imo.
    I've worked for both companies before i started my own and Kidde
    has had many issues with bad gauges, plastic parts and poor quality over the years.
    Also, the primary reason fire extinguishers/automatic systems are not available in Automobiles
    is that the Auto Manufacturers do not want consumers to think that their car(s) will catch fire.
    PC
  8. Jan 29, 2014 at 8:37 AM
    #88
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    That quick release one is bad ass!
  9. Jan 29, 2014 at 11:17 AM
    #89
    DannyD
    DannyD Well-Known Member
    Dan
    BC Canada
    2021 DCLB
    One question Ive never really found an answer for. What would happen if you use a BC dry chemical fire extinguisher on a typical class A fire. Typically any oil or gas (B) would also light up a class A material around it. My boat came with a BC extinguisher, which I transferred into my truck when I got rid of the boat. Should I replace it with an ABC?
  10. Jan 29, 2014 at 11:30 AM
    #90
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    +1 Ill jump in with ya!
  11. Jan 29, 2014 at 4:22 PM
    #91
    LikeABoss4x4
    LikeABoss4x4 Well-Known Member Vendor
    Sarah
    So Cal
  12. Jan 29, 2014 at 6:54 PM
    #92
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    How does that COLD FIRE extinguisher in a can actually work?
  13. Jan 29, 2014 at 8:45 PM
    #93
    uscg2008
    coby
    That's why we don't use them on our helos for fighting cockpit and cabin fires. We switch to more of a PKP style of extinguisher
  14. Jan 29, 2014 at 9:01 PM
    #94
    blackhawke88
    SGV, CA
    07 TRD Offroad
    it's just the cold fire chemical compressed. good to fight a car fire before it gets too big.
  15. Jan 29, 2014 at 9:44 PM
    #95
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    How does it compare to regular ABC extinguishers?
  16. Jan 29, 2014 at 10:04 PM
    #96
    killianeric
    killianeric Well-Known Member
    High Desert
    2007 Bass Model Tacoma
    My brothers amp behind the passenger seat caught fire in a drive thru last year. He didn't have a fire extinguisher in the truck. Luckily he got it put out before anything was burnt. The amp was destroyed. Audison said there was nothing they could do about it, since it's a rare problem. The only damage in the truck was the wood and the vinyl wrap was messed up, oh and the tint on the back window was melted a little. We got him a set of extinguishers for his birthday a few weeks later though. So he keeps one under his seat now, just in case.. I don't have the pictures of the amp destroyed, but heres a before picture.
  17. Jan 29, 2014 at 10:16 PM
    #97
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Someone needs to come up with a clean 2nd gen fire extinguisher mount. Wonder where? I have one under my back seat. It's not as accessible on long trips die to my stuff being back there. I want it easy to get at. Maybe something in the box, since I'll have a softopper eventually. But I would prefer a clean discrete cab mount. For a 5lb
  18. Jan 29, 2014 at 10:28 PM
    #98
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I know I'm not a 2nd gen, but I've kept this in my truck for the past 5 months. Hope I never need it....
    DSC_0022 by PcBuilder14, on Flickr
  19. Jan 30, 2014 at 1:24 AM
    #99
    blackhawke88
    SGV, CA
    07 TRD Offroad
    novataco[OP] likes this.
  20. Jan 30, 2014 at 10:43 AM
    #100
    jw1983
    Alberta
    What about a mount that goes behind the console. The only thing is that since that it's not flat up and down I am only thinking that you're only going to be able to have a mount that holds the top in. Unless you can make it extend out from the bottom so the holder will grab the extinguisher.
