fire wall holes
Discussion in '1st Gen. Tacomas (1995-2004)' started by houndsmen, Oct 21, 2010.
  1. Oct 21, 2010 at 3:09 PM
    houndsmen
    houndsmen [OP] Well-Known Member
    So I have a yaesu radio mounted and i had the antenna cable running thru the rear door on my 2001 tacoma double cab, well i pinched the cable and now im not getting as good reception as i was before. does anyone know where there is a hole in the back of the cab? i really dont wanna run it thru the front fire wall. so does anyone know where else i could run it thru? thanx
  2. Oct 21, 2010 at 3:11 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You can always drill one I don't know of any hole in the back of the cab.
  3. Oct 22, 2010 at 7:14 AM
    AlexanderD
    AlexanderD Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    There are 2 holes on the back of the cab. right near the bottom. they have plastic plugs on them. that's where i ram my antenna wires.
    cheers,
    AD
  4. Oct 22, 2010 at 7:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    Same here.
  5. Oct 22, 2010 at 9:48 AM
    houndsmen
    thanx guys...
    the ones that ran it thru the back of the cab where exactly does it come out? did you push it thru with a wire?
  6. Oct 25, 2010 at 5:21 AM
    AlexanderD
    Alex
    whitby Ontario
    naw man there are 2 plastic plugs. just take a look at the lower bit of the back of the cab under your bed. or if you look in the tool-box thingers in the cab you will be able to see the plugged.
  7. Oct 25, 2010 at 9:34 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I've also wondered about the little vents that are visible on the back of the cab between it and the bed... do those go through?
  8. Oct 30, 2010 at 12:54 AM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    There is two holes on each side of the cab, with plugs in them. I have my truck all apart, I can take pictures for you if you want. There are several plugs in the floor too that you could use, but the big plugs are just covers for the cab mount blot heads, they dont go thru.
