Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Jul 7, 2020 at 1:52 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    After some re-arranging of a few things in my basement, found a good spot for my new gun cleaning/work stand. Found a nice tall shop stool that's the perfect height. I have another LED Shop Light on order (same as above the other work bench), which I'll hang above.
    Hardscrabble, TomTwo, 95 taco and 5 others like this.
  2. Jul 7, 2020 at 1:55 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Does the other work bench have a stainless top?
    wilcam47 and RobP62 like this.
  3. Jul 7, 2020 at 1:59 PM
    Sig45
    Mark
    Maine
    No, just painted a darker gray.
  4. Jul 7, 2020 at 4:32 PM
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    Rookie work, I got this holster prior to getting the Leupold Deltapoint Pro. Optioned out for the Sig P320, but made it work for my M-18. Thankfully there was enough clearance for the trijicon suppressor height front iron sight. Some slight some trimming, of the kydex which was pretty forgiving, I managed to make it work. Once I find my dremel, I’ll clean up the rough edges, for a cleaner look. Not the best, but will have to do for now till I can get a M18 w/manual safety specific holster ordered up.
    TomTwo, Bannerman, RobP62 and 5 others like this.
  5. Jul 8, 2020 at 8:57 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Like a Pro! :fistbump:
    mcharfauros[QUOTED] likes this.
  6. Jul 8, 2020 at 9:09 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    TomTwo, RobP62, mcharfauros and 2 others like this.
  7. Jul 8, 2020 at 9:29 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  8. Jul 8, 2020 at 10:46 AM
    MadDaddy
    Many & varied
    Seeing as how the drawer slides into a thick housing, I am thinking it is an air vent to reduce a vacuum effect similar to when an ice chest with an air seal is slammed shut and sticks?
    TomTwo and RobP62[QUOTED] like this.
  9. Jul 8, 2020 at 10:54 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Makes sense to me I suppose. It definitely intrigues me to consider a biometric pistol safe mounted under the bed.
  10. Jul 8, 2020 at 1:39 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Finally got my Olight Odin I ordered on Launch. Took a couple weeks but was worth it.
    00100trPORTRAIT_00100_BURST20200706212848223_COVER.jpg 00100trPORTRAIT_00100_BURST20200706212932395_COVER.jpg 00100trPORTRAIT_00100_BURST20200706213004400_COVER.jpg
  11. Jul 8, 2020 at 2:16 PM
    MadDaddy
    Many & varied
    Nice Holosun combo to boot! I run the same set up.
    XPOTRPR[QUOTED] likes this.
  12. Jul 8, 2020 at 4:07 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks! Loving it so far. Zero issues too.
    MadDaddy[QUOTED] likes this.
  13. Jul 9, 2020 at 8:09 AM
    Sig45
    Mark
    Maine
    Spent some time this morning removing the trigger (noted above) and re-installed the factory Dan Wesson trigger. First time tackling something like this, but just took my time and was careful....not too bad at all looking back. Original trigger is 1000% better....never should have messed with it. Minimal take up (1/8") and zero trigger movement. I'm guessing 4ish lb trigger with the cleanest of breaks. I'm not even considering a replacement again unless I send it back to DW for a trigger job, but for now, I'm sticking with what I have.
  14. Jul 9, 2020 at 8:33 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Glad you got her back to stock. Sounds like you're perfectly happy with it, but I would think the experience should have given you the confidence to do your own trigger job in the future if you still want a bright finish trigger or to eliminate the rest of the creep. :thumbsup:
    https://www.brownells.com/handgun-p...1-competition-match-1-trigger-prod130417.aspx
    $20 and a little patience gets you full adjustability to set the trigger up however you like it. Changing out the mainspring is necessary to adjust the weight of the pull.
    RobP62 and Sig45[QUOTED] like this.
  15. Jul 9, 2020 at 9:00 AM
    Sig45
    Mark
    Maine
    Thanks, but I'm not sure I have the skills to install and then adjust a new trigger.
    RobP62 likes this.
  16. Jul 9, 2020 at 12:02 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Nice job Mark. What is the old saying. If it ain't broke.........:thumbsup:
    Sig45[QUOTED] likes this.
  17. Jul 9, 2020 at 12:06 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Is that just as easy with a P80 G17?
    [COUGH] BULLSHIT [COUGH]
    Seriously Mark, after the stuff I've seen you do recently? I think if I can build a P80 G17, then install and adjust a light, and then remove and install sights, then even I could would attempt to replace the trigger. I know you can do it. That is unless we are talking about two completely different trigger assemblies and yours is a 10 and mine is a 1 on a difficulty scale.
  18. Jul 9, 2020 at 12:18 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Entirely different trigger. I have no idea how to adjust a Glock trigger but I do know that polishing any contact surfaces makes a huge improvement over stock:thumbsup:
    RobP62[QUOTED] likes this.
  19. Jul 9, 2020 at 12:44 PM
    Sig45
    Mark
    Maine
    Live & Learn!!
    :fistbump:
  20. Jul 9, 2020 at 12:48 PM
    Sig45
    Mark
    Maine
    :laugh:
    I could do a simple replacement as that's what I just did. I just simply reinstalled a trigger that had originally been tuned for that firearm. But 1911's generally require fine tuning of multiple components when replacing a trigger. Zero experience in that field.
