Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Oct 12, 2022 at 8:03 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Quick question in regards to some ammunition storage concerns. My dad, who passed away May 2021, stored all his trap reloads out in the garage. I can’t even think how long they’ve been out there, maybe a decade? Probably 30+ boxes or so, so quite a bit.
    The garage gets really damp in winter, even though they’re in a closed cabinet so not necessary directly exposed.
    Any concerns about using these? If not safe to use, safe way to dispose of them? My thinking is they’re probably okay because the wad probably protects the powder well enough, but I don’t want to be wrong either.
    montijo505 likes this.
  2. Oct 12, 2022 at 8:05 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Should be fine.
    Laxtoy, Dacapster and montijo505 like this.
  3. Oct 12, 2022 at 8:09 PM
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    shoot em
    Laxtoy likes this.
  4. Oct 12, 2022 at 8:10 PM
    Dacapster
    Hugh
    14 trd
    Many coming
    The only rounds I have trouble with are Martini Henry British 1948 cordite rounds and those just have a 1 second delay.....
  5. Oct 12, 2022 at 9:59 PM
    Laxtoy
    Maltby, WA
    Thank you, probably move them inside at some point, as well as the 2 reloaders he left out there that are now both rusted to shit
  6. Oct 12, 2022 at 11:55 PM
    p1smo
    p1smo Well-Known Member
    2003 Tacoma TRD 4x4 3.4L 5MT
    Relentless Stealth front + Relentless standard rear plate bumpers w/ D2 cutouts, 2x Rigid D2 floods front + 2x Rigid flush D2 floods rear, BAMF behind-the-grille light bar mount w/ 2x Rigid 6" bar floods, KING coilovers/springs + rear adjuster shocks, Deaver leaf springs, Total Chaos UCAs, BAMF rock sliders, BAMF LCA skids, Relentless front skid, Low-Range Off-Road gas tank skid, Marlin differential plate cover, Marlin E-Locker motor guard, Hawke HD brake pads, Trail Gear steel brake line kit, Marlin HD full clutch assembly, deckplate intake mod + AFE high flow filter, ARB CKMA12, exhaust dumped over rear axle, 32/11.5r15 Cooper Discoverer AT3 XLT, American Racing Baja 15x8, Viper alarm + fuel cutoff switch, and more Toyota OEM parts + replacements than I care to list
    Worst that could happen is the ammo doesn't go bang, but there's no safety issue with firing it.
    wilcam47 likes this.
  7. Oct 13, 2022 at 6:00 AM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    I was in a similar situation and inherited a lot of birdshot that's probably older than I am when my grandfather passed. It was clear from the condition of the brass that they hadn't been stored in ideal conditions. My biggest concern with old ammo is squib loads caused by powder that has degraded from temp or moisture. My personal opinion (which is worth very little) is that with birdshot the risks associated with a squib load are significantly less than with pistol or rifle or even a shotgun slug. You're also going to know pretty quick when it doesn't go back into battery (semiauto) or a bunch of shot falls out when you cycle the action (pump). I've shot about half of the 300 or so rounds I inherited from my grandfather and haven't had any issues. They're a little bit lower power but I don't know if that's powder degradation or how they were loaded. I will say I don't hunt with it. I'd hate to have the first one not fire when I've got a good shot lined up.
  8. Oct 13, 2022 at 6:09 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    I'm also in the camp of shoot 'em!
  9. Oct 13, 2022 at 6:47 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Shoot them. Be aware (as you always should be anyway) of a round that doesn't feel right, and check the gun and barrel.
    And remember the good times you had shooting with your Dad.
    Laxtoy likes this.
  10. Oct 13, 2022 at 8:47 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    Do not look down the barrel from the front! Check the spent case/round or break the action.
    Dacapster, montijo505 and wilcam47 like this.
  11. Oct 13, 2022 at 9:15 AM
    Scott B.
    Scott
    Georgia
    Didn't realize that needed to be said.
    Also, you can use a cleaning rod - push it down the barrel to check for any obstructions.
    MAG GRY TACO15 likes this.
  12. Oct 13, 2022 at 1:13 PM
    CowboyTaco
    North Georgia
    11 TRD Sport
    I knew what you meant....but you never know if that is universally understood.
  13. Oct 13, 2022 at 1:47 PM
    Scott B.
    Scott
    Georgia
    You're right.
    As one who grew up guns, what is natural, normal and instinctual to me is not always that to others. Sometimes I forget.
  14. Oct 13, 2022 at 6:13 PM
    Laxtoy
    Maltby, WA
    I’d be shooting over-under so no cycling issues (and sighting down the barrel from the breach obviously not an issue) but it’d be pretty damn embarrassing shooting duds on the trap range
    Not trying to sound like an idiot and it’s likely not similar but old dynamite can become volatile, so just asking as a precaution
    Enigma8246 likes this.
  15. Oct 13, 2022 at 7:02 PM
    Enigma8246
    Lee
    Central Arkansas
    Even better.
    Anyone who has spent a decent amount of time on a range has done something embarrassing. Anyone who says they haven't is lying. My favorite embarrassing moment was not seating an AR mag properly while giving a demo to a new shooter on how easy ARs are to use. I pulled the trigger and the mag fell out.
    Nah. This is a question that comes up pretty regularly. Not necessarily here but it's common enough that there are tons of YouTube videos on the subject.
    Laxtoy[QUOTED] likes this.
  16. Oct 17, 2022 at 9:50 AM
    OhNoItsMe
    OhNoItsMe Well-Known Member
    NM
    2022 TRD OR
    After a couple of years of ownership, I finally got around to throwing some break in rounds down my .338 Lapua
    wilcam47, 308savage, PiryongS and 4 others like this.
  17. Oct 17, 2022 at 9:51 AM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    You have to save up money to shoot it? lol
    wilcam47, p1smo, TomTwo and 2 others like this.
  18. Oct 17, 2022 at 9:54 AM
    OhNoItsMe
    NM
    2022 TRD OR
    No kidding :rofl: that was a $140 box lol
  19. Oct 17, 2022 at 10:02 AM
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    My wallet ran and hid behind the couch just looking at this picture.
  20. Oct 17, 2022 at 10:44 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    He had the bullets on layaway :D
