Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Sep 14, 2023 at 8:11 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    You slingshot the slide on reloads?
  2. Sep 14, 2023 at 8:21 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Really worst case is I have a g19 that won't lock back on the last round. Not end of the world, but annoying.
  3. Sep 14, 2023 at 8:27 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    No, usually use the slide lock lever which probably has put more wear on it. I think the cause is b/c some of the milling done one the slide has made that rail on that slide stop side thinner than oem. If I flip the 2 slides over and look at the rail on that side in that area, it is noticeably thinner and thus worn faster. This is a bit of a fancy glock slide that I thought I wanted to build and after I was half way into it, I lost interest but was already committed to finishing it.
  4. Sep 14, 2023 at 8:33 AM
    JimBeam
    JB
    2015 Tundra
    who made the slide?
  5. Sep 14, 2023 at 8:40 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Southwest Precision Saber cut slide.
    Bottom right
  6. Sep 14, 2023 at 8:41 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I’ve been told not to do that because it can potentially get you off target, so I just stay on target and use my non-dominant thumb to operate the slide release because my fine motor control isn’t that great anymore as I get older.
  7. Sep 14, 2023 at 8:48 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    The perfect holster doesn’t exi-
  8. Sep 20, 2023 at 7:27 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I was going through my magazines, and came across these Butler Creek "Hot Lips" 25/22 magazines for a Ruger 10/22.
    I have 6 - 4 have never been loaded/fired, 2 were used a couple of times. I thought someone may be interested in them.
    Shipped for $75.00
    I also have a Ram-Line .22 Autoloader magazine loading device. It works with the above magazines, but not with Ruger factory mags. This is either unused or barely used.
    Shipped for $50.00
  9. Sep 24, 2023 at 11:07 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    .45 raptor project. Rounds use a modified .308 mag.
    None for sale that I know of other than 1 guy I heard of in AZ. that makes them.
    Mod requires a shortened follower then a spacer in the front with a feed ramp carved in.
    Have this 3D printed follower that needed serious trimming. Maybe with a little more shaping I can get it to work.
  10. Sep 24, 2023 at 5:43 PM
    H20man
    H20man USCG Polar Star WAGB-10
    The Rainy State
    2001 Tacoma Ext Cab 4x4 2.7L 5spd
    Bone Stock
    Sent you a PM Scott, thanks H20man
  11. Sep 24, 2023 at 5:51 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I've seen several inserts for sale on eBay.
    bkhlrTaco's[QUOTED] likes this.
  12. Oct 3, 2023 at 10:44 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Finally had time, and paperwork, to work on my PPS-43. Its "roughed" in so to speak. Barrel pin needs trimmed and then just some clean up and light sanding of the mag well area (mags fit to tight) and then clean up of the receiver. Then a few minor things like making the safety function.
    But did take it out and test fire 4 shots (all the ammo i had in the big garage lol). Not perfect with it being unfinished. Two rounds the bolt binded up a bit. But did get two to fire semi-auto. And boy the sights are way off......the orginal gun must have been quite out interesting as the front sight post is cranked way to the right.
  13. Oct 3, 2023 at 12:34 PM
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    Finally got around to taking this to the range this weekend. Shot like a dream! Until I got FTE every few rounds. I had put in an old PSA BCG in it when I replaced the BCG in my go-to rifle with a BCM. Swapped over the BCM at the range and it's GTG. Turns out the extractor spring was really weak. Luckily I already had a BCM sopmod bolt rebuild kit. So I rebuilt the old PSA with it. Should be good now.
    After shooting this rifle at the range, I switched over to my go-to 16" rifle. First thought was the loud ass twang of the buffer spring. :rofl:It never bothered me before. Not until I shot an AR with an actual stock. So I've got an Armaspec "stealth recoil spring" on order.
    YaboyDB_gen1 likes this.
  14. Oct 4, 2023 at 9:27 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    That's pretty sweet. Those are so fun to shoot.
  15. Oct 4, 2023 at 7:03 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    I was pretty happy with it even for having only put four rounds in it. Its surprisingly comfortable to shoulder and shoot.
    Ive got a PPS-43/52 (wood stock) kit that will be interesting to try out. Just have to decide where in line it ends up for being built. Though I only need a barrel (and the "permission slip") for that one unlike other kits I have.
  16. Oct 5, 2023 at 8:10 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    Posted this in the funny meme thread, but not funny?! Thought it fit here.
  17. Oct 5, 2023 at 8:11 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    LOL!
  18. Oct 5, 2023 at 8:21 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    This should be in every grocery store
  19. Oct 5, 2023 at 8:52 AM
    Archimedes
    23 DCSB TRD OR MGM
    Ask and ye shall receive (well, almost...)
    "Guns Groceries Guitars"
    Been here once or twice, three of my favorite things...
    http://www.northcountryfolklore.org/rvsp/countrystore.html
    Edit - haha, do NOT click on the musicoasis web link shown there....
    Stuck in VT and TomTwo[QUOTED] like this.
  20. Oct 5, 2023 at 9:30 AM
    TomTwo
    Bill
    I-85 Southbound
