Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Apr 12, 2013 at 8:22 PM
    #361
    Konaborne
    Konaborne [OP] Pineapples on pizza Hawaiian does not it make.
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    for whaaaayyyyyyyyy
    such a sexy wheelgun
    still mad at my dad for getting rid of his
  2. Apr 13, 2013 at 3:26 AM
    #362
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    An evil black something or other worth way more :cool:
  3. Apr 13, 2013 at 7:06 AM
    #363
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Seems like the point of walking the trigger is to use 2 fingers to pull the trigger at a higher RPM. Makes little sense to design a whole new action for that. I would start with the concept of a trigger extension. Do a little research and figure out what semi-auto .22 action is the fastest (a 10/22 would be a good starting point) and then machine up a skeletonized aluminum trigger extension. As long as the action is not modified to run more than one shot per trigger pull, you should be OK from an ATF standpoint.
  4. Apr 13, 2013 at 10:11 AM
    #364
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    finally got the base coat on my nova. Almost ready for the camo dip!
  5. Apr 13, 2013 at 12:11 PM
    #365
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    Problem with just lengthening the trigger is overcoming trigger weight, if you turn the trigger into an electronic switch, you can defeat the trigger weight
    And ya, I'd say a 10/22 is a good starting point, though I would actually start with a charger because of how you have to hold a paintball gun to walk the trigger (or how I do anyways)
    And it would probably need to be light too
  6. Apr 13, 2013 at 1:08 PM
    #366
    Polymerhead
    Missouri
    I say go for it. You might get some info or inspiration here.
    http://www.rimfirecentral.com/forums/showthread.php?t=317395
  7. Apr 13, 2013 at 6:51 PM
    #367
    crazyengineer
    patrick
    Bristol, TN
    I was actually thinking about that exact trigger, but put a pivot in the middle of the trigger like a sea saw and an electronic switch on each side so rather than having to reset the trigger I just have to pull the top trigger if that makes sense, or put light springs to keep it from hitting each one.
    heck, I could make it a bull pup and do that :D
  8. Apr 13, 2013 at 7:02 PM
    #368
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Interesting but make sure you do not cross the line of NFA rules for trigger manipulation.
    I think the powers that be just baned the old crank trigger operation deal that was very popular.
    Best of luck on the project and make sure you are not breaking the rules
  9. Apr 13, 2013 at 7:26 PM
    #369
    crazyengineer
    patrick
    Bristol, TN
    last I heard the cranks are not banned, what I am talking about is basically have 2 triggers that will each set off one round, it is just attached to a center pivot in a way that if one is fired, the other cannot fire until the first is released, so it will still only fire once per trigger pull, so there should be any difference. If it could be made as sensitive as some of the paintball triggers, you could easily get more than 10 rounds per second or so
  10. Apr 13, 2013 at 9:12 PM
    #370
    cKcs1
    cKcs1 Well-Known Member
    Jameson
    South Central KY
    00’ Ext Cab Tacoma
    me and a friend took up hydro dipping, doing small things for friends and others to make side $ and its pretty cool to turn a normal gun into something one off!
    here is a high point 380 in marble transparent film. Done a 2 tone paint job.
    and here is a 270 stock in transparent skull film
  11. Apr 13, 2013 at 9:28 PM
    #371
    shutterbug
    shutterbug Well-Known Member
    Cameron
    Downey, ID
    06 Blue Tacoma
    Trd intake, flowmaster exhaust, URD Maf calibrator, 3inch lift, Firestone Ride-rite airbags, Raceline 16" wheels, Fibeglass shell, carpeted bench kit, billet grill, Pioneer AVH1400DVD, Kenwood 150 watt amp, Kenwood 12" subwoofers, Access steering wheel controls
    My stress relief... I did the heggis spring flip, installed over travel screw and threaded my barrel at the machine shop and made the compensator to fit flush... shoots pretty good :)ade9a4e8_8bca510aa6b0f1eb86ece99d0220aee9af7675f7.jpg
    Next project
  12. Apr 13, 2013 at 11:24 PM
    #372
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    I love the idea of this, but I have a feeling that no matter how hard you try, if an authority were to look at that gun that you modify they'll find something wrong.
    Don't get me wrong, I'd love for this to be done and if you do it post pics!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  13. Apr 13, 2013 at 11:44 PM
    #373
    Ammo Toad
    Ammo Toad Ammo Toad
    Toad
    Panama City, Florida
    4x4 TRD
    Just getting started.
    I'm a diehard fan of the ultra concealable Rohrbaugh R9, 9mm. Ultra dependable too. many to choose from, but this is my go-to carry piece.
  14. Apr 17, 2013 at 12:35 PM
    #374
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    Sweet gun. I always wanted one, but I carry everyday and at work. I would shed a tear if I put that gun through the abuse I put my keltec through. I routinely have to clean my keltec to keep the rust off. --I work the beach sometimes and do ATV patrol and the sand gets everywhere. I can get 3 Keltecs for the price of one Rohrbaugh.
  15. Apr 17, 2013 at 6:36 PM
    #375
    crazyengineer
    patrick
    Bristol, TN
    so, has anyone heard about the .22 TCM? apparently it is a .223 that has been shortened a lot. first time I saw it was in a 1911 format, apparently R made by Rock Island.
    I haven't seen them in person, but after reading about them, I am intrigued
  16. Apr 17, 2013 at 6:47 PM
    #376
    Polymerhead
    Missouri
    If you love the 5.7x28mm but always wanted it in a 1911, the 22 TCM is your answer. You're dealing with the same issues a lot of wildcats face though - limited ammo and brass, limited bullet selection and limited shooting platforms. Life's too short - shoot what you want.
  17. Apr 17, 2013 at 7:02 PM
    #377
    Konaborne
    Cody
    Kealakekua, Hawaii
    The problem with proprietary rounds is that nobody controls market price but the maker
  18. Apr 17, 2013 at 7:43 PM
    #378
    crazyengineer
    patrick
    Bristol, TN
    Seems like you could make the brass from .223 if you are a reloader. It sounds like a fun cartridge. Maybe someday I'll manage to get one
  19. Apr 18, 2013 at 2:07 PM
    #379
    trdNick
    trdNick Odie
    Texas
    Got the barrel, forend, and magizine cap dipped last night. Came out pretty good! This stuff is not easy to work with for sure! I ran out of film so I ordered more to finish up the stock/receiver.
  20. Apr 18, 2013 at 4:53 PM
    #380
    Polymerhead
    Missouri
