Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Jul 16, 2015 at 10:32 AM
    #4561
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I had my 357 3" revolver selection narrowed down to the SP101 and when I went to pick it up I noticed a S&W model 60 - 3" in the cabinet. "Hmmmmm...let me take a look at that" I said. Both are great guns, but after handling each and especially dry firing using firing/snap caps....the trigger on the S&W sold me.
    If I ever see a great deal on the SP101 - I'd pick one up.
  2. Jul 16, 2015 at 11:02 AM
    #4562
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    I cringe when I hear "dry fire"
  3. Jul 16, 2015 at 11:03 AM
    #4563
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Snap caps save firing pins.
  4. Jul 16, 2015 at 11:04 AM
    #4564
    Sig45
    Mark
    Maine
    I had firing/snap caps...sorry I should have specified.
    SACTOWN[QUOTED] likes this.
  5. Jul 16, 2015 at 11:30 AM
    #4565
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    I just picked up a Ruger LCR 357 over the weekend and I shot it Tuesday when I was off what a great shooter.....
    I have a S&W 640 Pro that was a daily carry gun sometimes but was heavy at almost 8 ounces more then the LCR loaded
  6. Jul 16, 2015 at 3:39 PM
    #4566
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Dry firing does no more wear than live firing unless you're talking rimfires, because the firing pin can actually impact the chamber. What's bad about dry firing a revolver with empty chambers? (Nothing)
  7. Jul 16, 2015 at 6:12 PM
    #4567
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I must build this:
    95 taco likes this.
  8. Jul 16, 2015 at 6:58 PM
    #4568
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    holy shit i have a hexacopter and this would be too easy with a compact 9mm...
    i even have a free channel on the receiver for a servo to actuate it :rolleyes:
  9. Jul 17, 2015 at 6:06 PM
    #4569
    IPNPULZ
    going to be fun!
    I love this thing I picked this up over the past weekend...
  10. Jul 17, 2015 at 7:02 PM
    #4570
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    Use a .22 to reduce the recoil......
    Also if you have a camera mounted on it, mount it above the barrel and figure out a way to get cross hairs in the camera to line up
  11. Jul 17, 2015 at 7:11 PM
    #4571
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Just wire in a green laser.
  12. Jul 17, 2015 at 7:13 PM
    #4572
    crazyengineer
    patrick
    Bristol, TN
    PEQ 15 would be perfect
  13. Jul 17, 2015 at 8:03 PM
    #4573
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Another 250 rounds put downrange with my M11A1. 800 rounds total through the pistol so far and no FTE's or other problems. Doing well on normal controlled shots, but still trying to get my first double action shot correct when I practice drawing and putting two rounds down immediately. I'm still getting within about 6''-8'' from the bullseye at 7 yards on the DA shot, but I'd rather get it closer. My second shot (single action) gets within about 2'' of bullseye most shots.
    I like the "safety" feature of having my DA/SA, but it is definitely something to get used to when putting rounds out quickly.
  14. Jul 18, 2015 at 12:10 PM
    #4574
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    What's the difference between brass vs steel vs aluminum cased bullets? Does it really matter? Primarily for range ammo
  15. Jul 18, 2015 at 12:21 PM
    #4575
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Seriously considering a ruger lcp for pocket carry. Any reasons to look elsewhere i can grab one for about 299.99 at academy
  16. Jul 18, 2015 at 12:24 PM
    #4576
    Polymerhead
    Missouri
    You can reload brass. It's soft and offers the most reliability and can be cleaner shooting since it expands readily to seal the chamber. Aluminum offers about the same properties except it's not usually considered reloadable. Aluminum cases aren't really common. Blazer is about the only line I know of. Steel is common in ammo produced in Russia and eastern bloc countries. These countries used to use a green lacquer coating that would flake off in chambers and cause jams. Not usually a problem in guns like AKs with loose tolerances, but often caused issues in tight chambered ARs and other guns. Most current production steel ammo is coated with a gray polymer that causes fewer issues. Steel case is usually considered bulk/plinking fodder, loaded with cheap (sometimes bi-metal) bullets and not known for accuracy. Hornady has recently tried to change that perception by having steel case ammo loaded with their components to their specifications, attempting to make ammo that is both cheap and match-ready. They've had mixed success. Steel is not readily reloadable.
    Hope all that helps.
  17. Jul 18, 2015 at 5:58 PM
    #4577
    BadBrains
    AL
    I refuse to run steel cased ammo through any of my guns except for my AK. Tests have been done and it's shown that barrels are shot out after 5-6 thousand rounds. Malfunctions, broken extractors, damaged magazines.
    I've only gone through several boxes of aluminum cased 9mm. Ran fine, and aluminum is soft enough for me not to worry about extractors or a stuck case.
    Adventurer_Alex likes this.
  18. Jul 18, 2015 at 6:05 PM
    #4578
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    FWIW it will be ran through a glock. Sounds like I might stick to aluminum and brass. Thank you guys for the great responses @Polymerhead and @BadBrains
    Polymerhead likes this.
  19. Jul 18, 2015 at 6:13 PM
    #4579
    crazyengineer
    patrick
    Bristol, TN
    Picked up an SVT-40 today
    It's awesome!
    Bagman and blackhawke88 like this.
  20. Jul 20, 2015 at 11:30 AM
    #4580
    blackhawke88
    SGV, CA
    07 TRD Offroad
    lucky...how much?
