Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Dec 29, 2015 at 8:39 AM
    #5521
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    As mags go they are nice. Just the finish is the only thing that's not perfect. Other than that they look pretty much unused.
  2. Dec 29, 2015 at 8:56 AM
    #5522
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    HAHAHA. No, not wrong. It's cool. I'm a bigger guy, so the bulkiness doesn't bother me. I have a Kimber CDP II Pro, so its a 4", and has the acid melt edges specifically for carrying. Aluminum frame to save weight.
    The reason I asked, is because, I found this Shok Block on Wilson Combat's website, and didn't know if anyone had any experience using them. My 1911 is "bushing-less" so, I didn't know if they shok block was best used with a 1911 that had bushings or if it even mattered. Also, I wanted some feedback about the shok block itself.
  3. Dec 29, 2015 at 9:04 AM
    #5523
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Do you even 1911 bruh? No guns made out of dinner leftover containers allowed.
  4. Dec 29, 2015 at 9:08 AM
    #5524
    Roll Tide
    Q
    01 T4R
    The shok block is simply a poly buffer slid over the guide rod to reduce inertia and slam from the slide....pull the spring, slide on the shok block, reinstall spring, and you're done.
  5. Dec 29, 2015 at 9:12 AM
    #5525
    pittim
    Pennsyltucky
    Boujee Prius
    Sell those polys. Theres only room for real guns.
    It wouldn't be the Steelers if they didnt play below their opponent then have to work their way to a win lol.
    14489[QUOTED] likes this.
  6. Dec 29, 2015 at 9:26 AM
    #5526
    Roll Tide
    Q
    01 T4R
    Hey, I'm simply looking for thoughts a feedback. I suppose you COULD do that, however you'd have to cut it to fit over the guide rod...
    No, I'm not using special loads....I wouldn't think that you'd HAVE to be using special loads for there to be a benefit....
    Like I said, just looking for feedback....Also, thought that maybe the spring would need to be changed, as it would add some pressure, not much mind you, but it is kind of a spacer...so...
  7. Dec 29, 2015 at 9:31 AM
    #5527
    Roll Tide
    Q
    01 T4R
    Yeah...spacer lift...lol.
    So I cleaned the gun this past weekend, and noticed that the slide moves much smoother now, but I only used VERY little oil. Is there a different lube to use that will make it feel even more buttery?
  8. Dec 29, 2015 at 9:34 AM
    #5528
    pittim
    Pennsyltucky
    Boujee Prius
    I know in recoil buffers in AKs are basically snake oil.
    I'm guessing it's the same here. The guns been around for over 100 years. Recoil buffers have been around since at least the 60s, probably earlier. If they needed recoil buffers, the big companies who make them would be including them in the guns.
  9. Dec 29, 2015 at 9:35 AM
    #5529
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    If only that was the way the world worked..
  10. Dec 29, 2015 at 9:40 AM
    #5530
    pittim
    Pennsyltucky
    Boujee Prius
    If his gun functions fine now, and it's his carry gun, the last thing I'd recommend is to throw a piece of plastic in there that changes how the slide travels.
    Thats me though.
    It might save the frame a little bit, but realistically he doesn't live in CA so if his frame goes to shit he can walk into a gun store and walk out with a new 1911 he probably wanted to buy anyway that day.
  11. Dec 29, 2015 at 9:40 AM
    #5531
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Sig Sauer FTW
  12. Dec 29, 2015 at 9:48 AM
    #5532
    Fightnfire
    Marysville, WA
    I'm not arguing or disagreeing, simply saying the philosophy that "if it was better with it it would come that way from the factory" is a fallacy.
  13. Dec 29, 2015 at 9:52 AM
    #5533
    pittim
    Pennsyltucky
    Boujee Prius
    Yea, I get what you're saying. If it was truly needed, I'm sure Springfield or Kimber would throw in a recoil buffer and advertise the fact that it's included in their guns and not others. That's all I'm getting at. But the fact that isn't not even offered as an option says something about them.
    The things are $1.50/pc, it's not like they aren't including them because of cost.
  14. Dec 29, 2015 at 9:59 AM
    #5534
    Roll Tide
    Q
    01 T4R
    It functions fine, and has for the last 10 years.
    I used Rem Oil this time, as it was all I had...
    I didn't know if there was a "dry lube" that worked as well or better....
  15. Dec 29, 2015 at 10:04 AM
    #5535
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    I do..Sometimes a Kimber TLE,Colt or even my Sig Scorpion 1911's
    I'm 6'4 265 lbs and no issues carrying it...Va is a open carry state so if it shows some its no big deal but I do try to keep it covered at all times.
  16. Dec 29, 2015 at 10:10 AM
    #5536
    JB
    JB ....................
    Justin
    CA
    2015 Off Road DCSB
    ICON Stage 2, SCS Wheels, Toyo R/T's, 6-Speed
    Has anyone in here done the trigger upgrade on a Ruger LC9 or LC380 using the Galloway Precision kit? I installed it all correctly (at least I think I did) but the hammer won't drop when it is supposed to. Wondering if anyone else has run into a similar issue.
    jmaack likes this.
  17. Dec 29, 2015 at 10:13 AM
    #5537
    IPNPULZ
    going to be fun!
    http://gallowayprecision.com/FAQ/
    Not enough or to much over travel?
    I had an issue like this with my ZEV tech trigger bar where it had to be filed very little to fit.....
    JB[QUOTED] likes this.
  18. Dec 29, 2015 at 10:15 AM
    #5538
    JB
    Justin
    CA
    2015 Off Road DCSB
    Yes, I have been on there. I have also talked with a gun smith from the company. They recommended I bend a small tab on the trigger bar. I also know you can ground down the tab to be a little shorter.
    I was curious what experiences people have had in here.
  19. Dec 29, 2015 at 10:19 AM
    #5539
    IPNPULZ
    going to be fun!
    Thats what I did with my glock trigger bar and it worked fine.... I also went to far with the adjustment screw on my G19 and we all know happens then...
  20. Dec 29, 2015 at 10:22 AM
    #5540
    JB
    Justin
    CA
    2015 Off Road DCSB
    I'll give it a whirl and see what happens.
    Side note: I am plan on picking up a G19 next week.:cheers:
