Firearm BS thread
Discussion in 'Guns & Hunting' started by Konaborne, Dec 28, 2012.
  1. Dec 8, 2016 at 6:14 PM
    #8221
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Here is my final setup!
    ruffridha9, RickS, scottalot and 5 others like this.
  2. Dec 8, 2016 at 6:24 PM
    #8222
    02YotaGuy
    02YotaGuy Guy With A Red 80 Series
    Matthew
    Springfield, VA
    94 FZJ80
    Bumper, Winch, 315s, Sliders, OME HD lift, Custom rear swingout, roof rack, drawers, way too much to list.
    ^^^Very nice!
    I'd hate to be on the receiving end.
  3. Dec 8, 2016 at 8:26 PM
    #8223
    doyouquaxu
    doyouquaxu Well-Known Member
    Not bad for a brand new gun with junk range ammo. Shot down and to the left like every other new Glock I've gotten.
  4. Dec 9, 2016 at 4:56 AM
    #8224
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Those will not produce less of a fireball.
    jc11taco89[QUOTED] and smugly like this.
  5. Dec 9, 2016 at 5:01 AM
    #8225
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    But if thats a belly gun, all that fire ball goes in an assailant so theres that. Would That cauterize and stop the bleed?
    smugly likes this.
  6. Dec 9, 2016 at 5:09 AM
    #8226
    smugly
    Doug
    And blind him to!
  7. Dec 9, 2016 at 5:10 AM
    #8227
    Noelie84
    Noel
    Wales, Maine
    More likely it'd contaminate the wound with unburnt powder.
  8. Dec 9, 2016 at 5:38 AM
    #8228
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Are you tea cupping that thing for it to shoot like that?
    Out of my 7 Glocks none of mine shoot low and left out of the box my experience has been just left or right until I get the sights right...
    smugly likes this.
  9. Dec 9, 2016 at 7:12 AM
    #8229
    jc11taco89
    jc11taco89 Well-Known Member
    jon
    Naugatuck CT
    2011 Tacoma aclb 4wd
    3 inch toytec 5100 SPC uca's Pelfreybilt front plate bumper with center hoop Pelfreybilt rear plate bumper with swing out B.A.M.F. sliders with kick out Mobtown ifs and trans skid. 33's with rims that are to large.
    Nice so I see it doubles as a cigarette lighter/ flame thrower
    smugly likes this.
  10. Dec 9, 2016 at 7:26 AM
    #8230
    IPNPULZ
    going to be fun!
    So how much difference in accuracy between 6.5 24 inch and the .308 20 inch barrels would make a difference say @ 800/1000 yds?
  11. Dec 9, 2016 at 8:18 AM
    #8231
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    For good quality barrels the length doesn't effect accuracy if the bullet is stabilized, so as far as the calibers having different length barrels that should not be a factor.
    I'll let Smugly tell you about the difference in accuracy for 308 and 6.5, I have limited knowledge of the 6.5 but have read good things, I'm probably gonna end up building one.
  12. Dec 9, 2016 at 8:33 AM
    #8232
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The accuracy potential of both rifles isn't affected by the barrel length, but the 6.5 will have a much higher probability of hit than the 308. A 308 is not a good 1000yd cartridge by any means, not when there are so many better options easily available.
    http://precisionrifleblog.com/2015/04/25/how-much-does-cartridge-matter/
    smugly likes this.
  13. Dec 9, 2016 at 9:52 AM
    #8233
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    Due to the much higher ballistic efficiency of the 6.5 it is going to out preform the 308 at distance.
    Can the 308 preform at distance?
    Yes, been there done that, busting clay birds at a grand with the 308 just requires an intimate knowledge of what happens in the wind.
    30 cal 308-175gr SMK @2600fps in a 10mph full value wind has about 62" of drift
    7mm 708-162gr BTHP @2700fps 10mph full vale wind has about 38" of drift
    6.5mm 6.5Creed-140gr AMax @2800fps 10mph full value wind about 36.5" of drift
    As the bullets get smaller the cross sectional density is decreased (less surface area to be affected by the wind)
    Also bullets tend to get longer (long thin cross section bullets tend to stabilize quicker)
    Note that as the dia decreases the velocity tends to increase (the less time inflight to the intended target the less time it is affected by the wind)
    To get the 30cal to preform at distance similar to the 7mm - 6mm family you need speeeeeeeed
    To get the speed you need a bigger boom.
    30 cal 300WinMag-220gr BTHP @2850fps 10mph full value wind about 37.5" of drift
  14. Dec 9, 2016 at 9:54 AM
    #8234
    smugly
    Doug
    Obviously , you would think a longer barrel should improve accuracy ?????, but to be honest, there's just too many variables, to answer that question easily.
  15. Dec 9, 2016 at 10:06 AM
    #8235
    smugly
    Doug
    I hear a lot of people saying that barrel length doesn't affect accuracy, two that I call bullshit! Take something like a Nail and shoot it out of two different length tubes, and tell me which one is more accurate. in a most basic principle, that could very well be one of the reasons why the 6.5 Creedmoor is more accurate than the 308??????? Along with a bunch of other shit!
    The decision of the optimum barrel Length is determined by the manufacture via several conditions, weight grain of a load to burn ratios of the powders their using and so on
  16. Dec 9, 2016 at 10:09 AM
    #8236
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    A longer barrel will help with velocity, however there is a diminishing convergence, 22"-26" tends to be the sweet spot for 308s.
    When your tuning yer hand loads you're typically looking to have the powder burned up right at the muzzle, slightly before or after will work also.
    The bullet is being affected by the increase in pressure while in the barrel, burn the powder up too early your not going to build velocity the full length (subsonic is a different story)
    Too much powder is going to continue burning after the bullet has left, there is no more area to build pressure, it's a waste of powder and you create a muzzle flash that can be seen for miles, not good when trying to maintain concealment.
    scottalot and smugly[QUOTED] like this.
  17. Dec 9, 2016 at 10:11 AM
    #8237
    smugly
    Doug
    And vice versa, too long of a barrel will drag a bullet down
    P2W[QUOTED] likes this.
  18. Dec 9, 2016 at 10:14 AM
    #8238
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    Too long of a barrel, Yes!
    I remember some guys messing with 308s using 36" barrels in F-Class, it was short lived.
  19. Dec 9, 2016 at 10:30 AM
    #8239
    smugly
    Doug
    That's what happens when you mess with the recipe, ask the cook, LOL
  20. Dec 9, 2016 at 10:54 AM
    #8240
    Member1Zillion
    Member1Zillion Involuntary Kamikaze Co-Pilot
    Big Whiskey, WY
    '01 TRD, '17 Tundra, '07 FJ Cruiser, 94 PU, '18 T4R, '84 PU
    This, that, & the other thing
    Don't forget twist rate, grain, and ammunition type and material, barrel compostion and cleanliness also play a major role, as well as natural condions, i.e. wind, temperature, etc.
    smugly likes this.
